Old 04-06-2002, 09:37 PM   #1
fnoblitt
fnoblitt's Avatar
Question how do you hook up oil pressure guage?
i have a 69 c10 with factory guages it had a metal oil line that hooked up to the old 6cly. now i have a new 350 v8 and the oil line looks like it needs some sort of an adapter to fit it to the block.i bought a sun oil line kit witch came with some assorted fittings and a plastic line but none of the fittings work.(they work at the block if i use the plastic line but not at the guage)does anyone have or know exactly what i need ?thanks
70 c10 stepside ,350v8, m-20 4 speed
fnoblitt is offline   Reply With Quote
Old 04-06-2002, 09:48 PM   #2
bigjimzlll
bigjimzlll's Avatar
Post
I had to fool around with some different fittings..dont remember what
now, but what I do remember is to use the metal oil line...Thats what i was told anyhow...dont want the plastic one breaking and leaking oil all over
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-06-2002, 11:42 PM   #3
BUXMAN66
go bucks!
Post
go to your parts house and look in the accesory section that has all the guages and mr. gasket type chromy stuff. you'll see some oil line acc. stuff there. you need to get the copper 1/8th"line to do our trucks. the line will come w/all the fittings and stuff to do both ends of the line.at the engine block,(back rear edge of the intake manifold on the drivers side)and the back of the guage.put some loops on both ends to allow for any needed flex.stay away from the plastic line as invariably the rubbing at the firewall will put a hole in your line in time.good luck!
'68 swb 350/350 w/edelbrock toal perf.pkg.headers,flowmstrs.no rust of the mid-west on this one!
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 04-06-2002, 11:44 PM   #4
BUXMAN66
go bucks!
Post
also, forgot to tell you, your parts house can match up the thread and dia.of your fitting if what you need does not come supplied in the oil line kit.
