y not try to use thoes tahoe belts?
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
Tahoe was wrecked bad, belts had been cut or I would have used them. I tried to use everything I could.
i've got the stockers on mine i dunno what else may or may not fit
I just got through looking at some from a 99 Tahoe and at first glance, I think that they will work. You will just have to use the belts and the receptacles from the donor vehicle.
I am changing my interior color from light blue to gray. I have everything but the seat belts. It has been almost impossible to find a good set of gray seatbelts for an 85 Chevy truck. |
Happy to be here
![]() Join Date: Mar 2000
Check on Ebay. I see seat belts on there all the time. Of course I never see the "correct" seat belts for my 77, but I do see them....
It followed me home?
I have a friend running belts from a 90's ford aerostar. They work and look pretty good in there too.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
![]() ![]() Join Date: Jul 2002
On the 82, I have a set of belts from a 93 C1500 extended cab. They bolt right into the stock mounts. I found that with our 73-87 cabs, the belts from a standard cab 88-98 won't bolt right in, however the extended cab has a slimmer/and different mounting position that works great for these trucks. Make sure you keep the top bolt or get a good grade 8 bolt for the shoulder harness mount. The stock ones shaft is too thick for the newer truck belt mounts.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 10-12-2004 at 01:07 PM. Reason: I can't spell |
Signals in the bumper.
I have lap belts from Chevy Duty. I really want some oem ones though.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
I didnt like how the stock belts rubbed on my neck so I didnt wear them.
Its stupid not to wear seat belts so I bought some lap only belts to get me by till I get something with adjustable shoulder belt. Also my seat and seat belt nuts are stripped so i drilled out the seat belt nuts and put new nuts under the cab. Of course shoulder belts are better then lap belts, but lap belts are better then nothing. I couldnt find a pic with the seat installed. Here is a picture of what I have currently.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 10-12-2004 at 01:14 PM. |
