Old 10-11-2004, 11:34 PM   #1
arkracing
Weekend Warrior
Question Ctrl Arm Bushings
The Plan: 73+ Ball Joints in my '69 Ctrl Arms, PowerSteering Box from 73+, Steering Components from 73+, 2.5" dropped spindles from Early Classic up front, 4" Rear Drop Springs, Shock Relocators, Adjustable Pan-Hard.
****The Question: I've read in some other posts that stock ctrl arm bushings are steel and will actually result in a better handling truck (just a harder ride). Is this true??? or should I go with Polyurathane from Energy Suspension or something?
Stock or Poly???? Ctrl Arm Bushings? A hard ride doesn't matter to me I want it to handle a best as I can get it
Thanks guys - this board is great to newbe's to the 67-72 crowd
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 10-12-2004, 07:42 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you're using a set of 72 or earlier control arms, yes, they are steel bushings. Steel is very durable and theoretically will handle better due to no deflection.
There are currently no urethane replacement bushings made for 72 and earlier control arms, just stock steel replacements.
This has been argued about on here before. No one makes a urethane bushing for the older arms. Some folks advertise a urethane front end kit for 72 and earlier trucks, but they don't include urethane control arm bushings, just urethane sway bar bushings, tie rod boots and stuff.
Every time someone argues about it because they saw an ad for urethane 67-72 bushings, I tell them to call and order a set, and if they are urethane when they arrive, I'll pay them 50 bucks. I still have my 50 bucks, no one has ever seen a urethane replacement.
Your suspension plan looks like a good one. Only one thought, I personally, like to use either a Summit brand spindle or BellTech on 73+ applications. Don't get me wrong, I use ECE spindles a lot on earlier pre 73 trucks, including my current truck, but Summit sells their brand of 73+ spindles for much cheaper than ECE sells theirs for. Summit spindles are reboxed Western brand spindles.
Old 10-12-2004, 07:44 AM   #3
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
If your wanting to build a G-machine then there is alot more to it than just throwing parts at it.
I recomend a book by Herb Adams called Chassis Engineering, chassis design, building and tuning for high performance handling.
You might be suprised what you learn, save some money and wind up with a better handling truck to boot.
You can get it for about $15 from Amazon.com
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 10-12-2004, 07:50 AM   #4
arkracing
Weekend Warrior
Thanks TX
Thanks TX - I didn't know about the Summit spindles. I just thought ECE because they are garunteed for life - but I'm guessing that "Western brand" or BellTech are too - or are at least of the same quality.
-'66 C10 Suburban
Old 10-12-2004, 08:01 AM   #5
Joe67
67 is sold
Hey Ark. I'm in the process of something very similar on my truck.
I went with the front end rebuild kit (rubber) from www.p-s-t.com.
I had to pay extra for inner tie rods and sleeves, but the kit has gone together well so far.
Welcome
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-12-2004, 08:38 AM   #6
arkracing
Weekend Warrior
67c10Step
The PST kit came with Rubber upper and lower ctrl arm bushings??? or steel ones?
The only problem with using the kit is that i'm using the '69 ctrl arms and the 73+ ball joints/spindles/steering components - so it is hard to buy '69 bushings in a '73+ kit
-'66 C10 Suburban
Old 10-12-2004, 08:41 AM   #7
arkracing
Weekend Warrior
Exclamation Tx
Who is making the original Equip steel bushings for these? Moog? - i'm sure that LMC isn't selling moog products and i'm not sure which part strores carry them either?
how's your step side handle with the 4.5/6 in drop -- it isn't too much drop, I saw the pic of you truck and it doesn't look that bad, but in ECE the 4.5/6 looks real low. This is my everyday driver...so i was thinking 2.5/4 but now i'm temped to go 3.5/5 with the spindles and a set of 1' lower front springs.
Thanks for any input
-'66 C10 Suburban
Old 10-12-2004, 09:42 AM   #8
Tx Firefighter
You can buy Moog at most parts stores. Here, we have O-Reilley Auto Parts that stocks Moog stuff. By the way, Moog is the toppest notchest mostest bestest stuff for suspension.
My truck has no ill effects at all. I drive it all the time and drive it hard too.
I have 2.5 inch ECE spindles and 2 inch Summit brand front springs (actually reboxed Ground Force springs) and 6 inch rear springs. Mine sits like you see in the picture in my signature. I even run the same size tires as ECE trucks show on their stance section of their webpage.
I have a 4.5 front drop with my 2 inch springs, ECE actually uses a 1.5 spring to get a 4 inch drop. Also, my big block is very heavy, so it might weigh it down a little lower too. It's great though. No regrets at all.
