Old 10-12-2004, 09:04 AM   #1
tkeduk8r
tkeduk8r's Avatar
4bbl intake needed
does anybody have an old eiher cast or aluminum 4bbl intake for a chevy small block WITH the oil filler tube and cap??? I would like to add the script chevrolet valve covers w/o breather or filler holes to a 305 to swap in place of my 250??? thanks...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 10-12-2004, 09:31 AM   #2
1972C10
1972C10's Avatar
Ive got some old cast iron ones with oil fill.
1972C10 is offline   Reply With Quote
Old 10-12-2004, 10:16 AM   #3
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
I have both, but you wouldn't want to run the valve covers without a PCV valve though. Things could get messy with a frount fill.
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 10-12-2004, 10:21 AM   #4
racer94
if you run no pvc you better at least run a vented cap,if you dont run one or the other you'll blow intake gaskets and oil will go everywhere.i have 4bbl intake but none with fillers
racer94 is offline   Reply With Quote
Old 10-12-2004, 08:46 PM   #5
tkeduk8r
tkeduk8r's Avatar
Well ive seen some witht e PCV valve run right into the oil fill tube....cant remember what it was off of though... any sugggestions??? and i may have a line on a manifold here in MN but i need the filler tube with PCV... thanks for the help..
--Mike
Old 10-12-2004, 08:58 PM   #6
racer94
you do not have to have it right in the tube,you just gotta have a means of venting the top end.either through a vented oil fill cap on the valve cover(mr.gasket makes em),or a pcv in the valve cover....
Old 10-12-2004, 09:16 PM   #7
GROUCH
I Have A Cast One In Good Shape. Take $25 + The Ride From Abilene Tx 79601. Was Going To Put On E-bay But This Is Just As Easy. Can E-mail Pic If You Need. Part # Is 3905393. I Think It Came From A Old Malibu With 327
GROUCH is offline   Reply With Quote
Old 10-12-2004, 10:44 PM   #8
muddyole 69
filler tube vent
Had one from factory in my 66 vette with L79 I would assume all of thees engines both vette and nova would have them Mike
hav'n fun be'n me
muddyole 69 is offline   Reply With Quote
