Old 10-12-2004, 08:24 PM   #1
chipotledude05
Strategery
Arrow Shock Recomendations
What kind of shocks are you guys running on your 4x4s, and how have they been? I'm getting close to needing new ones, and I want to know what you guys think.
chipotledude05 is offline   Reply With Quote
Old 10-12-2004, 10:37 PM   #2
ProjectK-10
ProjectK-10's Avatar
I am running the Rancho RS9000's- not 9000x's(I bought them before they came out). They are a vast improvement over the trailmasters that were on there. They really softened up the ride. The nice part is that I can stiffen up the ride by just a turn of the 5 position dial. That is great for when I go hunting and driving on the washboard roads. I really like theses shocks. I want to get a set of 9000x's and the remote adjustment setup as well
'72 K-10 Longbed, 4" Lift, Rancho RS9000 Shocks, Trailmaster Springs(soon to be replaced), 35" Procomp Tires, Freshly Rebuilt 350, TH350, NP205, and More To Come
ProjectK-10 is offline   Reply With Quote
Old 10-13-2004, 12:17 AM   #3
Pont
I need another Barley Pop
Pont's Avatar
I'm running the same as ProjectK-10 and couldn't be happier with them! What's your budget? How much are you willing to spend?
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 10-13-2004, 10:18 AM   #4
poff
I run Bilstein stock replacements (longer than stock for my lift) and they work great.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 10-13-2004, 02:42 PM   #5
chipotledude05
Strategery
I'm restoring my 61 4x4 (no lift. I figure that its quite high enough as it is, and nobody makes one for a truck that old.) so money for shocks really isn't a problem. I like all the ones mentioned so far.
Old 10-13-2004, 03:07 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I run doestch's and love em got rancho's on my yota and hate em....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-13-2004, 03:14 PM   #7
pbmcauliffe
pbmcauliffe's Avatar
After runing Rancho (adj 9000's & standard 5000's), Pro Comp, SkyJacker and numerous others I tried a set of Bilsteins and now use them on every 4x4 buildup I do, unless I am installing big $$$ Fox, SwayAway, or King coilovers.
pbmcauliffe is offline   Reply With Quote
Old 10-13-2004, 05:01 PM   #8
poff
A good 4wheel drive shop should be able to order your shocks by length and end style without an application guide. We called Bilstein for my buddies '01 Tacoma because he lifted it 2" and they told us which shocks would fit. There is a way to jack up your truck and let the suspension hang and measure between the shock mounts then lower it and do the same. A good shop or manufacturer can tell you exactly how to do this. Then you just need to know the diameter and length of your mounts. I highly recommend the Urethane shock bushings.
Old 10-13-2004, 07:08 PM   #9
alf4444
alf4444's Avatar
I just replaced the stock 114k mile bilsteins (loved em') on my 97 with superlifts. I've only put about 100 miles on em so hopefully they get better but so far I don't like em too bouncy. Everything else I have has Tuff country shocks and I love them.
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 10-14-2004, 09:45 PM   #10
chipotledude05
Strategery
thanks guys
Old 11-01-2004, 10:52 AM   #11
HeavyK20
HeavyK20's Avatar
Are the Rancho RS9000's Gas or Hydraulic?
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 11-05-2004, 10:33 PM   #12
yfs200p
yfs200p's Avatar
where do you guys get Bilstein shocks and how much are they (ballpark) for 4?
'72 K10 SWB Fleetside. Avocado Highlander Frame Off Re-Creation
'72 K5 CST Highlander Project
'24 2500HD Z71 LTZ Duramax
'22 Tahoe Premier Duramax
‘03 2500HD ECSB 6.0L
yfs200p is offline   Reply With Quote
