Old 10-13-2004, 12:50 AM   #1
skokie
skokie's Avatar
Tranny Problem
THe 400 turbo is acting up. I am back to square one. The original problem was that if you put it in drive it would not shift out of 1st unless you went from D to N or D to L2 after that as long as you didnt take it outta gear it would shift fine. I changed the fluid and filter, governor, and vac modulator. It seems to be getting worse now because sometimes I have to shift the tranny twice to get it out of first. Anyone got any ideas on what else I can do beside bite the bullet and take it to the tranny man?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 10-13-2004, 05:08 AM   #2
RON WOODGEARD
Resident Young Old Dude !
Are You positive the tranny Linkage is adjusted properly Or isn't wearing in a spot causing a improper throw once in a while ??
RON WOODGEARD is offline   Reply With Quote
Old 10-13-2004, 06:25 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Did you check the vac line on the other end...is it getting plenty of vacuume?
Old 10-13-2004, 07:19 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
sound like either the linkage out of adjustment like Ron said or there is a piece of sludge etc. stuck in valve body.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-14-2004, 04:29 PM   #5
skokie
skokie's Avatar
Ron I am pretty sure that tranny linkage is adjusted properly but I am willing to double check it. What would be the best way to do that?
Longhorn Man. I have a vac meter how much should it be getting? I did the pull off technique and it had vac.
68 build thread
Old 10-14-2004, 04:38 PM   #6
cableguy0
sounds like there could be some crap stuck inside the valve body holding valves open and not letting them close when they need to
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-14-2004, 05:50 PM   #7
Longhorn Man
As long as there is vacuume, then the mod should work.
