Ebay Junky
? about installing bumpers
do i need to get anything else to install my front and rear bumpers? all i have are these rear outer bumper brackets:
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
67-72 Addict!
You need inner brackets also for the rear and top brackets for the front. Don't forget to correct front brackets for 71-72 bumpers. I also recommend all stainless hardware.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Be Careful when you tighten the bumper to the brackets you will dimple the bumper if you over tighten them. I would run a grinder over the face of the new brackets to remove any high spots.
I wrecked my rear bumper. So please trust me....
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
