Old 10-14-2004, 01:07 AM   #1
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Stupid window problems
My driver window keeps falling off track.I have changed almost everything to try and fix it.But if I roll it down,it will not go back up.It slips out of the track on the back side.
I didn't replace the regulator,cause I figured it went up,and down,that was all it was called on to do,so I left it.
I did change the back track,and the wing assembly,the window itself,hoping the track on the window was at fault,but still the same thing.It will roll down half way,then I have to rock the handle to get it to go down,and then it will not come back up.
It also looks as if the window is in a bind,cause it is trying to dig into the wing channel,and pull out the felt,
Anyone have a fix for this,I'm about ready to swap the door,and forget it.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-14-2004, 07:51 AM   #2
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Are the rollers intact? Sounds like one is broken or missing to me.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-14-2004, 08:39 AM   #3
Brainchild
Brainchild's Avatar
Yeah they are al there,I'm wondering if they are worn so much they are unusable though.
Maybe I'll swap the regulator today and see if it will work.
And it's raining too,go figure
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-14-2004, 09:53 AM   #4
MOTHERTRUCKERS
Did you remove the glass from the track the rollers ride in? did you get the glass back in the same position on the track?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 10-14-2004, 01:26 PM   #5
Brainchild
Brainchild's Avatar
I didn't remove the window from the track.In fact I swapped windows because the original one had fallen off.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-14-2004, 02:43 PM   #6
68plus4sub
68plus4sub's Avatar
Are all three of the rollers in? I'm sure you already checked, but I thought I would mention it, just in case!!
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt
2008 Kawasaki Concours 14
1997 Harley-Davidson Soft Tail Custom
1948 Chevrolet Coupe (project)
1972 Porsche 914
68plus4sub is offline   Reply With Quote
Old 10-14-2004, 07:55 PM   #7
Brainchild
Brainchild's Avatar
I got it fixed The weather stripping in the back channel was goobered.Someone trried to use 2 different pieces,and it would catch the track when I rolled it down.I replaced it,and all is good.
Lesson #1.Take nothing for granted when working on these old trucks.Check it 3 times before putting the eyecandy back together.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
