Old 10-14-2004, 03:10 PM   #1
jamie72
jamie72's Avatar
another problem...bleeding the brakes
I replaced pads and calipers last Saturday...bleed the brakes... pedal is still spongy. Thinking maybe I am not doing something right on bleeding the brakes, need a refresher course...lol. The truck is 98 chevy 1/2 ton 4x4 with ABS. I am thinking this Antilock braking system might mean I need to bleed the brakes a different way? Anyone have any ideas?
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 10-14-2004, 03:27 PM   #2
neonlarry
neonlarry's Avatar
I'm not sure if GM antilock is that way but some antilock systems require a computer(read dealer) to cycle them to bleed the system properly. One of many reasons I don't like antilock brakes. I always figured if you don't know how to drive without them you shouldn't be allowed to have a license.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 10-14-2004, 03:35 PM   #3
FormerMember
I have a 98 Burb. Same brakes. No special bleeding sequence required. Just bleed 'em some more. May want to flush the entire system.
FormerMember is offline   Reply With Quote
Old 10-14-2004, 04:07 PM   #4
oldsub86
Was the pedal spongy before you changed pads and calipers or only after? If it was not, then keep bleeding - all 4 wheels and if memory serves correct, start with the wheel furthest from the master cylinder.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 10-14-2004, 04:17 PM   #5
OhioDan
OhioDan's Avatar
Thumbs up
Jamie72, I've got a bleeding setup we use on forklifts sometime that are hard to bleed. Place a connection/hose on the bleeder, and a pressurized source on the other end. Crack the bleeder and back bleed them. Forces air from the brakes back to the master cylinder. Any chance of coming up this weekend, we'll bleed them? (If ya think it's safe to drive?) Workin on my truck Saturday, but I'll give ya a hand. Let me know.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 10-14-2004, 07:53 PM   #6
JimKshortstep4x4
Smile
I would try gravity bleeding, just open the bleeders and let the fluid run out instead of pumping. Of course you need to keep the mastercylinder full.
Jim
Old 10-14-2004, 07:58 PM   #7
jeffs98
I have a 98 as well and you do have to have it hooked to a gm reader to properly get out bubbles!! ALthough most of the time it is really not required!! Did you let the reservoir go completely dry?? Something else to remember is that these years of trucks are notorious for having spongy pedals anyways!! I changed almost EVERY component on mine before just giving up and dealing with it!!! Good luck!!
jeffs98 is offline   Reply With Quote
Old 10-14-2004, 10:23 PM   #8
jamie72
jamie72's Avatar
thanks dan, but i got to put it in the shop for a tranny problem this weekend,was hoping to fix this before i take it.
as for the mastercylinder going empty. the dealer did that for me,and the brakes have never been right sense,and i don`t go back to that dealer again...
thanks for all the in put
jamie
jamie72
member #807
www.antlertalk.com
Old 10-14-2004, 11:48 PM   #9
gaddman
gaddman's Avatar
Try this maybe...
Take a spare master cylinder cap/top and mount a vave stem, or an air hose connector so that you can hook up an air hose. Put a little air pressure (<10 lbs?) and then bleed each wheel, furthest away first. This has worked for me before.
Greg
Gaddman
Scottsburg, In
67 SWB w/93 step bed
68 LWB Fleetside C10 Custom
50 Chevy 3600
74 Norton Commando 850
72 Norton Commando 750
gaddman is offline   Reply With Quote
Old 10-19-2004, 10:19 PM   #10
jamie72
jamie72's Avatar
thanks everyone for the suggestions and help
jamie72
member #807
www.antlertalk.com
Old 10-26-2004, 10:50 AM   #11
RemoteControl
Hmmm, a lot of good answers here, but I haven't seen the basic one. Hooking a hose to the bleeder and insert other end into cup with clean brake fluid in it and pump brakes to see if there are bubbles still in system.
Just my 10 cents worth.
Rich
PEOPLE THAT THINK THEY KNOW EVERYTHING ARE PARTICULARLY ANNOYING TO THOSE OF US THAT DO !!
Dropped 93 Chevy Std Cab, 454 SS conversion, 20 in Centerlines, Wrap Around Ground Effects
RemoteControl is offline   Reply With Quote
