10-14-2004, 04:42 PM | #1 |
Tranny Shift kit.
What is a tranny shift kit and what does it do?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
10-14-2004, 05:01 PM | #2 |
The LuvShack Garage
Not A Expert, But I Think It Consists Of Hardened Springs And Other
Stuff I'm Sure, I Think It Helps Narrow The Shift Patterns And Helps The Gear Exchange Happen Faster, Reason Why My Tires Now Bark.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
10-14-2004, 06:08 PM | #3 |
a shift kit is a modification done to the valve body which normally includes new springs and fluid plates which direct the fluid inside the transmission. the shift kit springs are much tighter and stronger so they open and close the valves a lot faster causing the harder shift and eliminating slippage when the transmission shifts. and believe it or not a shift kit extends the life of the transmission even though its applying harder and faster the slippage is what kills the transmission over time and that is eliminated
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
10-14-2004, 10:51 PM | #4 |
Thanks guys. I was talking to a tranny guy today and he offered to put one in for no charge but wasnt sure what it did.
10-14-2004, 10:59 PM | #5 |
I bet his no charge shift kit included removing the Cervo Spring, Taking out the accumlator Spring Drilling a hole and removing two balls.
An Acutal shift kit can do the following depending on what kind Cheap 20 dollar plate set can .. Drill the hole and remove some balls. For Street Strip They Suggest Removing The Cervo Spring. A Good Shift Kit Comes With Alot of springs some of wich go into the valve body as well as a new accumlator spring. |
10-14-2004, 11:04 PM | #6 |
Thanks 1972C10. Im not sure I want him to do this since I am trying to build a stock truck even down to the tranny.
10-14-2004, 11:14 PM | #7 |
Yeah Shift Kits are good if its a mild one .. Most trrans guys feel they need to make them chirp the tires wich causes premature wear on parts.
10-15-2004, 01:33 AM | #8 | |
1972 LWB 4x4 1970 LWB 2wd 1971 chevelle 1972 datsun PL-521/nissan |
10-15-2004, 02:25 AM | #9 | |
Resident Young Old Dude !
You're absolutely right.. The slow shifting is called Overlap, ( robert's explanation) The general public doesn't want their head set back into the seat, They want a comfortable smooth shift. Because of the slow shift or "Overlapping" It's taking the tranny longer to release and shift from one gear to another. I have a street/strip kit in mine, Yes it does "Chirp" the tires from one gear to another if you are on the gas.. But if you're just driving with a soft Gas pedal it's a good bump. With most shift Kits, They have in the instructions ( Or at least used to) explaining this, Plus they will also tell you to go to "FORD" Type "F" Tranny fluid. It has better grabbing abilities then the Mercron, or Dextron. I have used Everything from the gentle shift kit to the Reverse Pattern, Full Manual... They are easy to install, having full directions.. Just be sure you keep the parts and inside the tranny Clean.. And they will make your Transmiision live longer as long as it's not old and worn out already. |
