Old 10-14-2004, 07:13 PM   #1
chucks70
rotor thickness?
What's behind this question is that I don't know what the donor vehicle was for my rotors and calipers, they may not even be from the same truck. I want to replace the calipers but is there a difference from say 1976 and 1982? I do know that the lug studs on the rotor have a larger diameter than my back wheels. I do want to match the caliper with the rotor if there is a difference.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 10-14-2004, 08:44 PM   #2
Rod
caliper years are limited between these eras.... 71-78 is the same.....79-80 the same .....81-86 the same.... so a 76 wont work with a 82 all according to my hollander manual looking up 1/2 ton ranges.
Seems the rotors will interchange as long as you have 2 3/4 inch rear brakes in your 82. There was a 2 inch rear brake in 81-86 era also, and there different... if I read this right.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
