10-14-2004, 09:11 PM | #1 |
How much drop with an axle flip (Leaf spring)
Does anyone know how much drop I will get out of a 1969 leaf rear axle flip?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
10-14-2004, 09:21 PM | #2 |
ummm, the thickness/diameter of the axle housing, bout 3 or 3 1/2 inches
64 Chevy pickup tilt,pb, ps discs up front 350/TH350, 72 rearend auto meter gauges 93 GMC extended cab trailmaster conversion |
10-14-2004, 11:14 PM | #3 |
oh yea, forgot the leaf spring pak, add that to it. A friend of mine bought a flip kit and the shackle hangers and his sit down bout seven inches. The hangers was two inches. He had to c-notch his frame also. Maybe that will give you some idea.
10-15-2004, 07:14 AM | #4 |
Watch out for your cornhole !
Usually, a flip kit nets 5 to 6 inch drop.
12-27-2004, 03:49 PM | #5 |
'70 GMC C-25 LWB
Where can you get a flip kit, and exactly what is contained in the kit? Seems pretty easy to fabricate, or get from a spring company. Thanks.
12-27-2004, 05:43 PM | #6 |
If you have a wood floor don't use the 2 " drop shackle it will hit the wood floor. ECE sells a 1.5" drop shackle for a good reason. I bought a 2" drop shackle and it is about 1/2 " too high and it hit's the floor.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-28-2004, 01:26 AM | #7 |
God Bless Mr. T
72Mario,
Thanks for the wood bed info! Much appreciated! James
Like a midget at a urinal...sometimes you must stay on your toes. |
