tranny swap questions
Has anyone switched a th-350 for a th-400? I just finished going from gas to diesel and now want to swap my tranny, I belive there is only a small size difference, so really only moving the crossmember and possibly new driveshaft
Remember the fallen. 9-11-01 ![]() 76 K5 4X4 custom roll cage/soft-top, turbo 400 & np 208 ![]() http://www.youtube.com/sp2fraggle http://www.oilfieldtrash.biz |
they also use a different kickdown (detent). the th350 has a cable, the th400 has an electric solenoid. and the dipstick tubes are also different. other than that, it's a direct swap, other than...like you already said, move the crossmember, and modify the driveshaft.
great, thanx for the help, always nice to confirm what your thinking before tearing things up.
The output shaft is larger on a TH-400 therefore you will need a new Yoke Shortened Driveshaft unless you have a 9" TH-350 And depening on what yoke you get you could need a 30 dollar conversion u joint Let me know what year and i can tell you what P/N If its pre 80 its a presicion 447
it is a pre 80 so the pn would apply, thanx
