Old 10-15-2004, 01:50 AM   #1
skokie
skokie's Avatar
Carb heat shield on cast iron intake?
Is a carb heatshield necessary on a cast iron intake for either a quadrajet or holley?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 10-15-2004, 05:33 AM   #2
JimKshortstep4x4
Smile
If your engine has the manifold where the exhaust passages run under the carb you will need a shield. (If the manifold has a groove between two holes in the front).
Otherwise under normal driving you don't need it.
Jim
Old 10-15-2004, 01:36 PM   #3
skokie
skokie's Avatar
Jim
How can I tell what ports are what? I can post a pic later tonight of the intake.
68 build thread
Old 10-15-2004, 07:49 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I replaced my stock cast iron manifold (with exhaust crossover) because it cracked, but it had no heat shield when I bought it (in 1977), nor did I have any problems with too much heat in the q-jet. Wouldn't a heat shield prevent the exhaust from heating the choke mechanism - which is the reason for the crossover to be there?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-15-2004, 08:21 PM   #5
JimKshortstep4x4
Smile
This is a pic of a manifold that needs a heat shield. It is a BB Q-Jet manifold but older small blocks had the exhaust holes and groove under the carb. If your manifold does not have the holes and groove in front than you don't need a heat shield.
Jim
Old 10-15-2004, 09:20 PM   #6
grayw0lf
You know, you can always pick up a nice used Edelbrock or similar aluminum intake on Ebay for around $40-50.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 10-15-2004, 11:45 PM   #7
skokie
skokie's Avatar
Looks like I need to use one. I already have one but I am not sure its the correct one. I will do a test fit and see.
68 build thread
Old 10-16-2004, 12:07 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Question Well, now I'm confused...
My intake didn't have that passageway across and ahead of the carb. It's been quite awhile, but I seem to recall an internal exhaust passage going across and through the manifold.
- Mike -
RIP El Jay
Old 10-16-2004, 05:46 AM   #9
JimKshortstep4x4
Smile
Stocker,
They quit making manifolds with the grooves in them in the late 60's. The holes pictured in the groove go down into the exhaust passage that you are thinking of.
We tap the holes with a 3/8 npt and screw in pipe plugs, (flush style). The holes tend to plug and there is a good chance of an exhaust leak under the carb when the holes are not plugged.
Jim
Old 10-16-2004, 09:57 AM   #10
1978steven
1978steven's Avatar
This is my first post on the forum and I think this intake question might relate to something I have been working on. I have a 1971 Chevy and I was getting it ready for winter driving. So I was pulling out the stuck open thermostat, that has been in it more than likely from the factory, when both bolts holding the water neck on snaped. So I pulled the intake to take it to work and get the bolts out. I got the bolts out and decided since the intake was off I'll clean it up paint it and put back on. Well, the heat sheild under the carb on the bottom of the intake was packed full of carbon build up. I am assuming this heat sheild I'm talking about is the same as the one in question above? My intake does not have the grove cut in it like the pictures above.
So, is it safe to remove the shield to finish cleaning the intake up?
Thanks for the help,
Steven
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
Old 10-16-2004, 10:24 AM   #11
GMC AMI
GMC AMI's Avatar
This intake will require the shield.
With this intake the heat shield is very important. The thin metal shield is shaped just like carb. gasket. Without this the regular gasket will burn out
and cause an exhaust leak in a short while. The port helps warm up the gas
sooner to help old ROCHESTER carbs. I never saw one on a Holley. If they did
it has to be for a spreadbore pattern.
Welcome to the board 1978steven ! The shield in ? goes on the top of intake
under carb.
GMC AMI is offline   Reply With Quote
Old 10-16-2004, 10:51 AM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up
Ah, that explains it! Thanks for the info!
- Mike -
RIP El Jay
Old 10-16-2004, 05:20 PM   #13
1978steven
1978steven's Avatar
Red face
My Bust!
Thanks for the clearification Mike Files.
2004 Tahoe LT
1971 Chevy C10
