10-15-2004, 07:56 AM | #1 |
Big Block Motor Mounts/Towers
Bought a set of BB towers off of here (thanks 69 1/2 Six Pack Bee, they are really nice) But have run into some questions. When i lay they into the frame it appears they do not fit perfect and lay a little crooked. Do I have to drill new holes, I would have thought all the frames would be drilled from the factory to except either SBC or BBC? If I do need to drill holes that is fine but how do I know where to place the mounts??
Any help would be great, maybe someone has pictures of how their's looks thanks
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
10-15-2004, 10:53 AM | #2 |
Resident Curmudgeon
When I did this using 72 BBC mounts on a 71 frame, we had to drill one hole in the crossmember. 3 holes (2 on framerail, one on crossmember lined up) and I'm pretty sure we used the forward (V8) position too.
Sorry no pics
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
10-15-2004, 01:19 PM | #3 |
"forward V8 position"??? Still not sure if I know where to place them??
Any pictures thanks
10-15-2004, 03:01 PM | #4 |
Senior Moment
I too am interested in this as I'm going to be doing this useing 72 mounts on a 70 frame
Pic would be nice Thanks Duramax for starting this thread
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
10-15-2004, 03:15 PM | #5 |
Almost Satisfied
Here is a pic
of the 72 BB stands. I will have to drill the hole in the crossmember once the engine is ready.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
10-15-2004, 03:33 PM | #6 | |
Resident Curmudgeon
10-15-2004, 03:49 PM | #7 |
Thats awsome, thanks for the pic. I know I can get it positioned right now.
Now just need to fire the motor on hte test stand before dropping her in....then its time thanks guys
