Old 10-15-2004, 12:06 PM   #1
Bobalouie
Fetzer Valve Technician
Bobalouie's Avatar
Anyone with a Hollander Manual?
Could you look up and see what front disc brakes interchange on a 1972 Chev 4x4?
Thanks.
1972 Chevy K10 SWB
Bobalouie is offline   Reply With Quote
Old 10-15-2004, 01:12 PM   #2
JJR
JJR's Avatar
Here you go (I did a cut and paste so don't think I typed it all):
BLAZER/JIMMY (full size) 71-76 4x4
BLAZER/JIMMY (full size) 77 4x4, early
CHEVROLET PICKUP TRUCK 71-76 10 Series; 4x4
CHEVROLET PICKUP TRUCK 77 10 Series; 4x4, early
GMC PICKUP TRUCK 71-76 1500 Series; 4x4
GMC PICKUP TRUCK 77 1500 Series; 4x4, early
SUBURBAN 71-76 10 Series; 4x4
SUBURBAN 71-76 1500 Series; 4x4
SUBURBAN 77 10 Series; 4x4, early
SUBURBAN 77 1500 Series; 4x4, early
325068 $290 obs
Early '77 inner bearing stpd. LM603049/LM603011; late '77 inner bearing stpd. LM104949/JLM104910.
Rotor same as 1501. (below is 1501 applications)
BLAZER/JIMMY (full size) 77 4x4, late
BLAZER/JIMMY (full size) 78-82 4x4
BLAZER/JIMMY (full size) 83-91
CHEVROLET PICKUP TRUCK 77 10 Series; 4x4, late
CHEVROLET PICKUP TRUCK 78-88 10 Series; 4x4
CHEVROLET PICKUP TRUCK 89-91 1500 Series; VIN model "V" (4x4)
GMC PICKUP TRUCK 77 1500 Series; 4x4, late
GMC PICKUP TRUCK 78-87 1500 Series; 4x4
GMC PICKUP TRUCK 88-91 1500 Series; VIN model "V" (4x4)
SUBURBAN 77 10 Series; 4x4, late
SUBURBAN 77 1500 Series; 4x4, late
SUBURBAN 78-87 1500 Series; 4x4
SUBURBAN 78-88 10 Series; 4x4
SUBURBAN 88-91 1500 Series; VIN model "V" (4x4)
Rotor same as 1522. (below is 1522 applications)
CHEROKEE 77 late, hub & rotor
CHEROKEE 78-83 hub & rotor
GRAND WAGONEER 84-91 hub & rotor
J-SERIES TRUCK 77 J10 (6 stud wheels), late, hub & rotor
J-SERIES TRUCK 78-88 J10 (6 stud wheels), hub & rotor
WAGONEER 77 late, hub & rotor
WAGONEER 78-83 hub & rotor
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 10-15-2004, 03:32 PM   #3
Bobalouie
Bobalouie's Avatar
I am not really sure how to read that. I assume that the first section is for Calipers? Am I correct in the assumption from the info above that the 72 rotors do not interchange with the 73 rotors? Can you also give me interchange info on the spindles?
1972 Chevy K10 SWB
Old 10-15-2004, 07:39 PM   #4
JJR
JJR's Avatar
I have the CD version of Hollander on my work computer and when you do a search you have to put "front brakes". It will not let you put rotor. It will let you put caliper and spindle. The rotors on any of the listed vehicles will work (basically 71-91). I will not be at work until Tuesday so I will check on the calipers/spindles then. Hope this helps.
Old 10-19-2004, 10:51 AM   #5
JJR
JJR's Avatar
Here is what I came up with on calipers/spindles.
Calipers
BLAZER/JIMMY (full size) 71-78 Front; 4x4
CHEVROLET PICKUP TRUCK 71-78 Front, 10 Series; 4x4
CHEVROLET PICKUP TRUCK 71-78 Front, 20 Series; 4x4
GMC PICKUP TRUCK 71-78 Front, 1500 Series; 4x4
GMC PICKUP TRUCK 71-78 Front, 2500 Series; 4x4
PONTIAC 69-70 Front
SUBURBAN 71-78 Front, 10 Series; 4x4
SUBURBAN 71-78 Front, 1500 Series; 4x4
SUBURBAN 71-78 Front, 20 Series; 4x4
SUBURBAN 71-78 Front, 2500 Series; 4x4
Spindle (early)
BLAZER/JIMMY (full size) 71 4x4
CHEVROLET PICKUP TRUCK 71 10 Series; 4x4
CHEVROLET PICKUP TRUCK 72 10 Series; 4x4, early
GMC PICKUP TRUCK 71 1500 Series; 4x4
GMC PICKUP TRUCK 72 1500 Series; 4x4, early
SUBURBAN 71 10 Series; 4x4
SUBURBAN 71 1500 Series; 4x4
SUBURBAN 72 10 Series; 4x4, early
SUBURBAN 72 1500 Series; 4x4, early
3979676 R. or L.
Early '72 used on vehicles with axle ident. 603351 or 603352; late '72 used on axle ident. 603333 or 603334.
Spindle (late )
BLAZER/JIMMY (full size) 72 4x4
BLAZER/JIMMY (full size) 73-75 4x4, spindle
BLAZER/JIMMY (full size) 76 4x4, horizontally mtd. (tie rod) grease fittings, spindle
BLAZER/JIMMY (full size) 76 4x4, vertically mtd. (tie rod) grease fittings, spindle
BLAZER/JIMMY (full size) 77 4x4, small bearing (1-25/32" I.D.), spindle
CHEVROLET PICKUP TRUCK 72 10 Series; 4x4, late
CHEVROLET PICKUP TRUCK 73-75 10 Series; 4x4, spindle
CHEVROLET PICKUP TRUCK 76 10 Series; 4x4, horizontally mtd. (tie rod) grease fittings, spindle
CHEVROLET PICKUP TRUCK 76 10 Series; 4x4, vertically mtd. (tie rod) grease fittings, spindle
CHEVROLET PICKUP TRUCK 77 10 Series; 4x4, small bearing (1-25/32" I.D.), spindle
GMC PICKUP TRUCK 72 1500 Series; 4x4, late
GMC PICKUP TRUCK 73-75 1500 Series; 4x4, spindle
GMC PICKUP TRUCK 76 1500 Series; 4x4, horizontally mtd. (tie rod) grease fittings, spindle
GMC PICKUP TRUCK 76 1500 Series; 4x4, vertically mtd. (tie rod) grease fittings, spindle
GMC PICKUP TRUCK 77 1500 Series; 4x4, small bearing (1-25/32" I.D.), spindle
SUBURBAN 72 10 Series; 4x4, late
SUBURBAN 72 1500 Series; 4x4, late
SUBURBAN 73-75 10 Series; 4x4, spindle
SUBURBAN 73-75 1500 Series; 4x4, spindle
SUBURBAN 76 10 Series; 4x4, horizontally mtd. (tie rod) grease fittings, spindle
SUBURBAN 76 10 Series; 4x4, vertically mtd. (tie rod) grease fittings, spindle
SUBURBAN 76 1500 Series; 4x4, horizontally mtd. (tie rod) grease fittings, spindle
SUBURBAN 76 1500 Series; 4x4, vertically mtd. (tie rod) grease fittings, spindle
SUBURBAN 77 10 Series; 4x4, small bearing (1-25/32" I.D.), spindle
SUBURBAN 77 1500 Series; 4x4, small bearing (1-25/32" I.D.), spindle
Old 10-19-2004, 11:22 AM   #6
djracer
djracer's Avatar
jjr
will a complete 2wd 12bolt rear out of a 67 be the same as a 66
Kevin
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-19-2004, 11:22 AM   #7
Bobalouie
Bobalouie's Avatar
Thanks Man.
1972 Chevy K10 SWB
Old 10-19-2004, 11:51 AM   #8
JJR
JJR's Avatar
djracer, here is what shows for a 66 C-10 2WD rear axle assembly (drum to drum):
CHEVROLET FORWARD CONTROL 65-69 10 Series
CHEVROLET PICKUP TRUCK 65-66 10 Series 4x2; 12 bolt cover
CHEVROLET PICKUP TRUCK 67 10 Series 4x2
CHEVROLET PICKUP TRUCK 68-69 10 Series 4x2; 12 bolt cover, coil springs
GMC FORWARD CONTROL 65-66 1000 Series
GMC FORWARD CONTROL 67-69 1500 Series
GMC PICKUP TRUCK 67-68 1500 Series 4x2; 12 bolt cover
GMC PICKUP TRUCK 69 1500 Series 4x2; 12 bolt cover, coil springs
SUBURBAN 65-66 10 Series 4x2; 12 bolt cover
SUBURBAN 67 10 Series 4x2
SUBURBAN 67-68 1500 Series 4x2; 12 bolt cover
SUBURBAN 68-69 10 Series 4x2; 12 bolt cover, coil springs
SUBURBAN 69 1500 Series 4x2; 12 bolt cover, coil springs
Assembly includes hubs & drums.
On '65-66 the sway bar attaches to a cast ear on the carrier.
It may be necessary to change the parking brake cable when interchanging.
Old 10-19-2004, 11:56 AM   #9
djracer
djracer's Avatar
Thanks JJR
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
