Old 10-15-2004, 05:10 PM   #1
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Question Vin # Help
PLEASE TELL ME ALL YOU CAN, TRYING TO TRADE FOR HER
Cs337s121030
THANKS FOR ALL YOUR HELP, LUV
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-15-2004, 05:25 PM   #2
Robo_bot
Robo_bot's Avatar
did u look at the blue one in the backround lol ill take a look and see what i can find for ya
Robo_bot is offline   Reply With Quote
Old 10-15-2004, 05:28 PM   #3
Robo_bot
Robo_bot's Avatar
2 wheel drive, Six Cylinder, 1ton, the other 3 i dun know, 1967 year, St. Louis assembled, 121030 unit made
Old 10-15-2004, 05:36 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
SORRY, BUT THE BLUE ONE IS A F@RD
Old 10-15-2004, 05:37 PM   #5
Robo_bot
Robo_bot's Avatar
oops my bad
Old 10-15-2004, 05:37 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Glove Box Has Only Like 4 D@mn Options, But It Does Say 133" Wb
Old 10-15-2004, 06:10 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
1967-1972 VIN Number Codes
Example: CE149J 100001
Chassis Designation (1st digit)
C= 4x2
K= 4x4
Engine Deisgnation (2nd digit)
E = V-8 Gas
S = Six Cylinder Gas
GVW Range (3rd Digit)
1 = 1/2 Ton
2 = 3/4 Ton
3 = 1 Ton
Model Code (4th Digit)
4 = Pickup with Cab and Bed
Model Year (5th Digit)
7 = 1967
8 = 1968
9 = 1969
0 = 1970
1 = 1971
2 = 1972
Assembly Plant
A = Atlanta
B = Baltimore
F = Flint
J = Janesville
N = Norwood
P = Pontiac
S = St. Louis
T = Tarrytown
Z = Fremont
1 = Oshawa
Vehicle Serial Number
100001 = 1st Unit Built
All this found on a link off the HOME PAGE
Old 10-15-2004, 06:16 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Thanks longhorn, I knew about that but was trying to determine any other
info that might go with it, dtlilly said somethin about a certain number that
may designate longhorns ? not sure what he was talking about, if I recall
correctly when I looked at the glovebox it said 133", is that just because
it is a 1 ton ? or is it possible it has longhorn ties to it ? just curious, I am
looking to better my situation by trading my 70 4 t, guy is very interested.
Old 10-15-2004, 07:02 PM   #9
Longhorn Man
Go to the smae page and look at the model numbers....or just click on the link in my signiture for model numbers.
Being a one ton will automaticly make it a 133 or 157 inch wheel base. Only if it came from the factory with a fleet side bed on it, would it be a longhorn. It could have came with a 9 foot step side, or nothing at all...just a cab and chassis truck.
Either way...what ever it was, you can make it a longhorn with just a bed.
The model number will be listed in the glove box on the option sheet.
Old 10-15-2004, 08:48 PM   #10
Rod
The second 3 nobody answered means i was ordered as a cab and chassis... it had no box.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 10-15-2004, 09:21 PM   #11
Gator70
Gator70's Avatar
Anybody know if the Canadian trucks used a different code. My truck is a 70(9/69) K15 long box with ser KE1341Z........ I am the second owner of this truck so I know that its what it should be. Any insight would be appreciated.
Gator70 is offline   Reply With Quote
Old 10-15-2004, 09:54 PM   #12
Longhorn Man
it is becouse it is a GMC...post your VIn and we can decode it for you.
Old 10-15-2004, 10:14 PM   #13
Longhorn Man
Rod, very good point. I didn't even read it, just copied the info onto the thread.
So from your VIN alone, we know it is not a longhorn.
Old 10-15-2004, 10:20 PM   #14
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
OH, I C, MIGHT EXPLAIN THE F@RD FLATBED ON HER BACK
Old 10-15-2004, 11:06 PM   #15
Gator70
Gator70's Avatar
No its not a longhorn ser# goes like this KE1341Z50721. The truck is a '70 K15 longbed. thanks for the help
Old 10-16-2004, 09:55 PM   #16
Rod
Well I'll try to answer a couple question in this post. The vins on a 1 ton wont say if its a longhorn or not...vins only tell certain info... more of a model number will tell if its a longhorn or not. I dont think anyone calls a 133 inch wheel base single wheel cab and chassis a longhorn, as its the box that makes it a longhorn as far as I'm concerned. I agree with Longhorn Man that whats posted eliminated the longhorn reality due to lack of a box explained in the vin. The vin in this case also dosent explain the wheel base being either 133 or 157... again the model number or actually seeing a picture would need to be known also. Really we had a picture of a dually here so its more just info on decodeing vins I'm writing about it here. 1 tons came 133 or 157 wb... but have have seen an extended 1 ton chassis also.
As for Gators vin... Another version of the GMC way of doing things.
KE1341Z50721
K = 4x4
E = eight cylinder
1 = 1/2 ton
34 = wide side- fleetside box
1 = Oshawa Assembly plant in Canada
Z =1970
sequence number is the rest
Old 10-17-2004, 12:23 PM   #17
Gator70
Gator70's Avatar
Thanks for the decode Rod, anybody want to help me scrapre the grease off so I can code the engine
1970 GMC K15 - Canadian built
2nd Owner truck 68k miles
2014 Denali 1500 6.2L
