Old 10-16-2004, 11:23 AM   #1
b454rat
BBC in a 4wd
I want to take the 454 out of my 89 and put it in my 62 4wd Suburban. From what I hear, you can't get the motor mount anymore. I have the single saddle style mount. I pretty much have all the parts I need to do the swap, and really want to get it going, and this is biggest hold up. Does anybody have or know where I can get this mount, or know a way to put it in without breaking the bankfor custom mounts, or major fab work??
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 10-16-2004, 01:21 PM   #2
86dieselburb
Have you looked at LMC or Classic Industries for the motor mount? Big block wasnt around in 62 so the closests you will get is a small block mount. Also, the 73-87 trucks motor mount crossmember can easily be removed and I would bet it's a close fit to your 62 frame. If not some minor fab work could make it fit. This way you can get motor mounts from any autoparts store. On the 73-87's, small block and big block mounts are the same.
86dieselburb is offline   Reply With Quote
Old 10-21-2004, 04:18 PM   #3
Burt4x4
Burt4x4's Avatar
I just put a 73+ crossmember and frame horns in my 72K5, duno if it's the same or not? but thought I would share anyway...
Check my post in the 69-72 Blazer fourm
Good Luck
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
