Old 10-16-2004, 10:03 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
One solution for low hanging exhaust
I just couldn't leave well enough alone!! I was ready to pull the frame outside to degrease before taking to the sandblasters, and thought I would try to do something about the low hanging exhaust problem.
I want this truck to sit lower than it did before getting munched. But, the way the exhaust had to pass under the middle crossmember (the one the carrier bearing mounts in), I didn't want to go much lower.
So, here is what I did. I think it should work OK. Material is 1/4" mild steel.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-16-2004, 10:16 PM   #2
mikeoj
Nice job!What size pipe you runnin?
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 10-16-2004, 10:17 PM   #3
Drop Top 71
I don't get the hint that banned means banned
Drop Top 71's Avatar
truely trick
Drop Top 71 is offline   Reply With Quote
Old 10-16-2004, 10:24 PM   #4
67cst
i love summertime
67cst's Avatar
hey looks good, and kinda familliar
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 10-16-2004, 10:44 PM   #5
glock35ipsc
2 1/4"
Bob
Old 10-16-2004, 10:44 PM   #6
glock35ipsc
GMTA!!!
Bob
Old 10-16-2004, 11:55 PM   #7
ed455
Captain Ed
Where did you find flat washers that big???
ed455 is offline   Reply With Quote
Old 10-17-2004, 12:05 AM   #8
glock35ipsc
They are not washers, I cut them out of 1/4" plate, then cleaned them up inside and outside on the lathe.
Bob
Old 10-17-2004, 12:25 AM   #9
gonebad2
Merciless Butcher
gonebad2's Avatar
That is sweet!!! That's exactly how Chevy did it on 3rd generation Vette's. Monday I pick up a 72 Blazer that I'm turning into a 2wd. I want to run my exhaust the same way. Looks great!
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 10-17-2004, 01:12 AM   #10
Hutch
Hutch's Avatar
glock35ipsc
I have seen this modification done by several board members and on ECE's website.
I think this is a great idea for routing of the exhaust.
My question is:
Does it interfere with the emergency brake cables as in the original set-up?
When I asked the question of the other folks doing this mod they stated they did not have or need an e-brake.
Cars and trucks have to have a functional e-brake to pass state inspection here in Texas.
Also it appears that you a doing away with the carrier bearing.
Do you have to have a custom drive shaft made if so how much do they usually run?
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 10-17-2004, 02:02 AM   #11
gonebad2
Merciless Butcher
gonebad2's Avatar
Hutch, I had a one piece drive shaft made for my 67 short fleet this past August. It included the tubing, end yokes, U joints and slip yoke for a turbo 350. All parts were new and the total was $290.00. You may be able to get it done cheaper if you take one in and have it shortened.
Old 10-17-2004, 02:15 AM   #12
ZOOMY
plasma cutter
What brand plasma cutter do you have ?
ZOOMY is offline   Reply With Quote
Old 10-17-2004, 04:06 AM   #13
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
It does looks kind of familliar..... without the stainless steel clamps.... Great job !!!
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 10-17-2004, 04:11 AM   #14
67cst
i love summertime
67cst's Avatar
glock--- GMTA ?
Old 10-17-2004, 08:03 AM   #15
ed455
Captain Ed
I realize that, I was joking.
Old 10-17-2004, 09:26 AM   #16
glock35ipsc
I actually do have washers bigger than that at work. But the O.D. was too big, they would have hung out past the crossmember at the top and bottom. I had originaly intended to weld these to the inside of the x-member, but would have been too hard to weld.
We make parts for coal mills for power plants, so we make some pretty big stuff! We have some 4" diameter X 24" bolts at work, along with flat washers and nuts!
Bob
Old 10-17-2004, 09:28 AM   #17
glock35ipsc
glock--- GMTA ?
Great Minds Think Alike :p
Bob
Old 10-17-2004, 09:34 AM   #18
glock35ipsc
Originally Posted by Hutch
glock35ipsc
My question is:
If you look at the pic that shows both holes, you can see the holes for the e-brake cable with the grommet in them at the bottom outside of each hole I made. But, since I am going to an automatic, I am still debating the use of the e-brake. I will prpbably end up installing it.
This frame is a 72, and it has a mount for a pillow block type bearing, one that bolts to the bottom of the x-member. My 68 had the type that bolted to a bracket at the top of the x-member and hung down. Since that bearing only has about 200 miles on it, I wanted to remove the old bracket and bearing and use it on this new frame. I may have a one piece made later.
Bob
Old 10-17-2004, 09:42 AM   #19
glock35ipsc
It is a Thermal Dynamics Econo Pac 50, great machine!
Bob
Old 10-17-2004, 01:41 PM   #20
67cst
i love summertime
67cst's Avatar
ahh yes! makes sense now LOL
Old 10-17-2004, 03:14 PM   #21
FirstGen
Just Don't Stop!
FirstGen's Avatar
doesn't someone like Brothers, ECE or similar company make a replacement bolt in piece with this design?
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 10-17-2004, 03:38 PM   #22
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That is slick ... I guess the lowest part of the frame would be the carrier bearing mount??? Good idea for getting it down lower.....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-17-2004, 07:42 PM   #23
SCOTI
SCOTI's Avatar
Early Classics has the replacement crossmember w/exhaust holes. It offers more clearance @ the top of the driveshaft hole & is level w/the bottom of the frame vs. how the stock c.member drops about 1.5" in the center.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-17-2004, 08:02 PM   #24
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Hutch, I had Ft Worth Gear and Axle build me a 1 piece driveshaft for my truck. It was 200 bucks, total including a new Th400 yoke, U joints, shiny paint, everything.
