Old 10-16-2004, 10:15 PM   #1
soleeagle
soleeagle's Avatar
The Big Score
The other day I ran into an old freind. We got to talking about our vehicles and I had told him I was looking to fine a set of 3/4 ton axles. He told me that he had a truck with a busted tranny and trasfer case sitting in his yard. I ask him what he wanted for it and his reply was, "If I could find some one to pull the motor out of it they could just have the rest of the truck". I told him I was his guy and today we pulled it to the shop and went to work. In about 45 minutes I had the motor out. I Got the axles out tonight ad found that they have 4:10 gears in them. I do have a question, how do I tell the difference from a 3/4 ton and a 1 ton rear? The brake drums just look a little big to be 3/4 to me. I am guessing that it is a GM 14 bolt but not sure how to tell the difference. It does have 14 bolts around the cover and the penion bolts in from the front too. If any one could help I would appreciate it. I took pics with my phone but it wont let me send them for some reason.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 10-17-2004, 12:40 AM   #2
1969 GMC
1969 GMC's Avatar
Chuck,
both the 3/4 and 1 tons had the 14 bolt rearend. The 1 tons had narrower perch spacing, but I am unsure of the measurement. What front axle did you get? If it is a dana 60, then it was a 1 ton.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-17-2004, 09:13 PM   #3
smokkey1
Land Beast
1 ton 40.5" center spring to center spring
3/4 ton 42.5" center spring to center spring
I bought an 1 ton 14 FF yesterday with 4.10's and open carrier for $85
but I need to move the spring perches and shock mounts since it's going in my 3/4 ton sub.
90' GMC 1 Ton Suburban
smokkey1 is offline   Reply With Quote
Old 10-18-2004, 04:16 PM   #4
toddol1971
Originally Posted by soleeagle
The other day I ran into an old freind. We got to talking about our vehicles and I had told him I was looking to fine a set of 3/4 ton axles. He told me that he had a truck with a busted tranny and trasfer case sitting in his yard. I ask him what he wanted for it and his reply was, "If I could find some one to pull the motor out of it they could just have the rest of the truck". I told him I was his guy and today we pulled it to the shop and went to work. In about 45 minutes I had the motor out. I Got the axles out tonight ad found that they have 4:10 gears in them. I do have a question, how do I tell the difference from a 3/4 ton and a 1 ton rear? The brake drums just look a little big to be 3/4 to me. I am guessing that it is a GM 14 bolt but not sure how to tell the difference. If any one could help I would appreciate it. I took pics with my phone but it wont let me send them for some reason.
this is your quote "and the penion bolts in from the front too.It does have 14 bolts around the cover " This tells me that you have an eaton ho52, or ho72. I want to say this is the origonal 14 bolt. someone will correct me if im wrong on the origonal 14 bolt part. Hopefully it has a no spin.
All my trucks are gone now. I'll gladly take a free one
toddol1971 is offline   Reply With Quote
Old 10-18-2004, 04:51 PM   #5
smokkey1
Land Beast
does your axle look like this?
Old 10-18-2004, 11:58 PM   #6
soleeagle
soleeagle's Avatar
Your pic dosnt show up, so I cant answer that.
Chuck
Old 10-19-2004, 01:17 AM   #7
1969 GMC
1969 GMC's Avatar
if it has 14 bolts holding the diff cover on, then its a 14 bolt for sure.
Eaton H052/72 only had 10 bolts in an uneven pattern, plus the Eaton's diff is round and has a dropout third.
However they both have 14 bolts holding the ring gear to the carrier.
1969 GMC K2500
1996 Honda Accord
Old 10-19-2004, 01:42 AM   #8
Mudder
Mudder's Avatar
Heres his pic.....
Mudder is offline   Reply With Quote
Old 10-19-2004, 07:19 AM   #9
toddol1971
Yeah mudder thats probably the one he has. when he said the pinion bolts in from the front, I just thought he meant the 3rd member. Sorry if i caused any confusion. Can anyone answer whether the eatons were considered the origonal 14 bolts or not? thanks Todd
Old 10-19-2004, 06:42 PM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Todd, the eatons-H072/H052 were the predessecors(sp?) to the 14 bolt which appeared in 1973, the eatons were used from I believe 1947-1972.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-19-2004, 11:31 PM   #11
soleeagle
soleeagle's Avatar
Originally Posted by Mudder67
Heres his pic.....
Yep thats what it looks like. Thanks for all the info everyone. I am still learning about some of these things.
Chuck
Old 10-20-2004, 12:15 AM   #12
smokkey1
Land Beast
cool. now if it's an open carrier you can drop in an detriot.
http://www.off-road.com/chevy/tech/detroit/
Old 10-20-2004, 11:03 AM   #13
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
good article!
