my gas saver
single or double wall???
i am gonna take the top off of the blazer soon to work on it. i think it is a singlewall and wanted to know the differences? here are some pics if they help, thanks, eric.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
huh ???
That is a single wall. The bolts on a single wall go down from the top side, on a double wall they come up from the bottom...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Dag awn
which one?
which top is better to have and why are were two different ones made?
1972 K/5 CST Blazer 4x4 |
huh ???
I think the single wall is better as the double wall tends to sag in the middle. Couldn't say why they made two differend ones...
Chuck
my gas saver
yeah the bolts do go from the top, thanks.
#6 | |
Premium Level Member
Don't think double wall tops had inside lights. I think single wall was only made in '72. I've heard that single walls also sag. The tops are so huge that the fiberglass just weakens over the years, bracing was at minimum to keep weight down.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
#8 | |
huh ???
Chuck
I don't get the hint that banned means banned
My trucks FROM Montana as far as i know, and the Original owner got a double wall.... So maybe they were better at keeping heat in? I know the truck has a block heater too, apparently the (cold)weather was an issue in a previus life? It's a 71 and if they really didnt start making single walls untill 72 - then that's definetly why its not a singlewall! MY $0.02
my gas saver
mine is a 69, it must have been changed out. it is in excellent shape too. i just wondered why everyone seems to want to get rid of their double wall for a single wall?
#11 | |
"1972 C5"
The bolt hole locations are different for single and double walls so if you think your truck originally had a double wall and now has a single top just check the bed top rails for evidence of 2 sets of holes.
#13 |
Good stuff. So is it a fact that singles were only made in 72? It seems to me that with cost mgmt, its VERY possible that GM went into a single wall design to save $$. Does anyone have an options list for the 72 that shows cost of either . I'd bet that the double would have cost more. Good information if we can figure it out.
#14 |
The Blazer King
1.Double wall IS heavier. (pain in the but)
2.Double wall is harder to bolt on/off because bolts go in upside dow and you can't see to allign. (pain in the but) 3. Double wall has threaded holes/truck does not. Single wall does not have threaded holes/truck does. 4. Who want's a top anyway? We own convertibles for a reason. ha.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
#15 |
my gas saver
that`s all i plan to do is leave it in the garage when it`s raining. i don`t want to invite half the neighborhood over to get the top on and off all of the time. oh wait i don`t have neighbors, guess i`m s.o.l. ha.
#16 |
All valid points, I have a double wall for my '71, and yes it is heavy. I have heard from single wall owners that the weight difference is not that great. You may need 3 or 4 people to remove/install a double wall, but for the single you probably need 2 or 3.
So, don't think of it as a pain in the a**, think of it as an excuse to have a party, get some brewskies, turn on some tunes. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#17 |
Well me and my girlfriend put my double wall on with some "thinking". Really was not that difficult. Of course if your paint is worthy, then it might be a different story
#18 | |
Further more i don't think anyone will find you need more or less people needed to put on/take off a double/single wall top. From what i know, and what jakeslim said, a double wall is POSSIBLE to get on with only two(2) people. I've taken mine OFF with only one other friend before. I'm sure a single wall is even easier, that's all. How ever i always called up as many pals were around to make life that much easier. That's the nice thing about California for us blazer owners, NO SUMMER RAIN!....we take the top off for all of summer, and when it starts to rain, we put the tops back on untill next summer! |
#19 | |
This is correct, I had to relocate the holes on the bedsides I am using for my Jimmy. There were just holes and I had to fill them in and make oval holes and weld on nut keepers on the underside. |
#20 |
the double wall has threaded holes in it, the truck does not.
#21 |
Hmmmm maybe I'm reading this incorrectly or my trucks weird? Probably my first guess. I had a double wall and when i took it off and on , the bolts that bolted it on threaded into/out of the Blazer. My double wall top had 4 brackets, 2 up on the window frame, and 2 near the tail gate. They matched up with threaded holes IN my blazer. I guess i see what you're all sayying, the 2 i didnt bother with were the ones under the bed rails behind the doors. I guess those would have had to thread into the hard top.
#22 |
The Blazer King
[QUOTE=Drop Top 71] My double wall top had 4 brackets, 2 up on the window frame, and 2 near the tail gate. They matched up with threaded holes IN my blazer. I guess i see what you're all sayying, the 2 i didnt bother with were the ones under the bed rails behind the doors. [QUOTE]
I would say that is is unsafe without the side rail bolts. Very scary. There are: 1 in each visors 2 in middle of windshield frame 4 in each side of bedrail 1 in each rear corner.
#23 |
So that's what all those holes in my bed rails are for, 4/10 aint too bad
#24 | |
Toys: 72 K5 Blazer 74 Vette |
#25 |
My 72 jimmy has both sets of holes.
LT |
