Old 10-16-2004, 11:42 PM   #1
jakeslim
Premium Level Member
jakeslim's Avatar
What is it!??
Ok, in my 69 k5, there is something with a knob/lever below the steering column. Today as I started and backed it up on its own power for the first time since buying it, I noticed the knob moving when I pushed the brakes. What is it. It looks like its from the 60's or 70's .
thanks,
jakeslim
jakeslim is offline   Reply With Quote
Old 10-16-2004, 11:44 PM   #2
sdkid
Is it a separate box under the dash? Could be a trailer brake control unit.
sdkid is offline   Reply With Quote
Old 10-16-2004, 11:45 PM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Sounds like it's a trailer brake controler. It's used when you have a traier with electric brakes on it...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 10-16-2004, 11:51 PM   #4
jakeslim
jakeslim's Avatar
Its a separate box, abot 4" wide and 1" high with a lever. The lever will not budge at all, but it did move when I pushed my brakes. What would that have to do with a trailer and how would it help electric trailer brakes. I thought it might be some sort of brake assist or something, but then again, have no clue
Old 10-16-2004, 11:55 PM   #5
sdkid
Probly has a line going to the master cyl. Has maybe 2 wires going into it. Push on the brakes and the fluid pressure causes a switch in the control unit to close. Sends power to the trailer wiring plug.
Old 10-17-2004, 12:09 AM   #6
jakeslim
jakeslim's Avatar
thanks! I'll probably remove since I'm not pulling a trailer.
Old 10-17-2004, 01:29 AM   #7
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Yeah I think that's almost a option when you buy any old truck here in MO.I have a pile of those things I've taken off.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-17-2004, 05:02 AM   #8
Drop Top 71
I don't get the hint that banned means banned
Drop Top 71's Avatar
They're so you can match the pull of the brakes on the trailer and tow vehichle so when you step on the brake they're both (vehichle and trailer) even and slow down at the same rate! You dont want your truck/trailer braking one more so then the other.
Example: While working we had to pull X tons of grapes on a utility trailer. We unloaded the fruit and forgot to set the grab of the brakes back DOWN after the fruit was off. Imagine what happend as soon as we lightly tapped the brakes on the way back, and the trailer brakes were still set for multiple tons...instead of non(no load)! Major tire smokage! The truck(F350) barely slowwed, while all four trailer tires locked up. Oooops
Anyways i got one stuck on my blazer too and highly doubt i'm ever going to pull anything so big it'll have trailer brakes. So what's the cleanest way to take one out and deal with the wires etc??
Drop Top 71 is offline   Reply With Quote
Old 10-17-2004, 10:14 PM   #9
Woody1
I don't know the cleanest way to remove one but I was thinking about one the other day. I had borrowed the neighbor's trailer and pulled my JD 650 tractor with a box blade about 100 miles (interstate driving). Also had my Yamaha Big Bear 400 in the back of the truck and a bunch of other heavy stuff in the truck and trailer and got to thinking it, "It would be nice to be able to hook up the trailer brakes on this thing sence I'm still running Drum Breaks".
I would like to have a set up if one of you would like to part with one. Please let me know....
Thanks,
Woody1 aka Woody
Woody1 is offline   Reply With Quote
Old 10-17-2004, 10:26 PM   #10
silvertonguedevil
silvertonguedevil's Avatar
DON'T TOUCH IT!!!! It's the ejector seat lever!
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
