![]() Join Date: Aug 2001
puff of blue smoke
noticed today that when i press in the clutch to shift from third to fourth (3,000 rpm), i will get a quick puff of blue smoke from the tailpipe when the clutch is released. 4,000 miles on 327 since complete stock rebuild. thoughts?
Valve seals or guides. What was done to the heads for the rebuild?
machine shop rebuilt them. i'm thinking they were knurled which might be the problem?
I hate knurling, just a band-aid. Could be your problem.
just got off the phone w/ a mechanic i know.............he thinks it might be a ring since it also is smoking a little on hot startup. i don't want to tear this thing apart already!
Lovin' Life in Miss.!
What is knurling?
The truck... you hear that? No really, you did hear that?!!! |
69 C-10 project
it is like what you get on some of the handles a ratchet or breaker bar has for grip, cross patterns, it pushes the metal up in some places to take up the play in the guide, usually only temporary.
69 C-10 Work is complete |
Is this done on the head itself, inside or outside of the guide? Not on the valve!?
Rich
Keep On Truckin'
Its done on the inside wall of the valve guide where the valve stems fits.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
well i had a leak down test done today.............inconclusive on the oil burning. all cylinders are consistent w/in 10% and are all like 95% sealed. spark plugs were all consistent too. they looked pretty good. the mechanic told me to put some more miles on it till a suspect cylinder shows up (like a misfire). asked him about the knurling (although he's the one did them, but still is a straight shooter so i believe him) and he said that he didn't think that would be the issue. said that since they had not been knurled before, they had a quite a bit of material to work with and they wouldnt be leaking enough to exhibit these symptoms. he did acknowledge that both sides are burning to some extent.
