Old 10-17-2004, 12:48 PM   #1
rolson1039
column question one more time
i did not recieve a reply last time so im going to try this one more time, but im going to make it simpler on me
I have a 1976 c 10 which is equipped with a 3 speed and manual steering
I have a column which is from an 80s truck which has the wiper switch in the turn signal. and was equipped for power steering
MY question is can i swap out the turn signal switches from the columns and maybe the colar where the turn signal stalk comes out so this way i have an automatic power steering column that will fit my 1976.
I cannot afford to buy a column at this time already factory equipped to handle what i need, so i was hoping to just rig up what i need
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 10-17-2004, 01:02 PM   #2
Russell
Professional Grade
Russell's Avatar
While I am out looking for someone else's steering shaft piece, I'll look and see if I have the signal cam that you'd need to convert the steering column over...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-17-2004, 02:13 PM   #3
badone07
Project 2 Resume
badone07's Avatar
sent you a pm rolson1039, which may help.
John
1984 C30 Chevy Crew Cab Dually
1998 Jeep Cherokee 4x4
2004 Chevy Trailblazer 4x4 (wife's)
1970 Mustang FB fully tubed (getting 521 BBF & powerglide)
1978 Nova 2dr (going BBCaddy & S.P. th400)
1984 Monte SS (circle track car)
badone07 is offline   Reply With Quote
Old 10-17-2004, 04:21 PM   #4
rolson1039
thank you both!!
