Old 10-17-2004, 10:37 PM   #1
orange72
orange72's Avatar
door hinges
ok guys ive got a question. im trying to get my hinge pins out of my door hinges so i can install new ones but im having a hard time trying to knock them out. is there an easy way in doing this. i ground the pointed end off flush with the rest of the hinge but still no movement in the pin when i hit it. any help would be appreciated
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 10-18-2004, 12:06 AM   #2
grayw0lf
I can sum it up in one word...Pneumatics. Buy yourself a cheap (or good) air hammer/chisel & they usually come w/ a few chisels.
Hit it w/ that & be patient. It'll just sit there hammering, hammering, hammering, & then all of a sudden it starts to move. WD-40 & about 2-3 days time helps too.
You'll need another small rod (like a center punch for driving finishing nails flush) b/c the chisel will be too bid to chase the hinge pin the entire way.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 10-18-2004, 12:47 AM   #3
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
when I did mine I had to beat the krap outa them with a 5lb hammer. I added heat from a propane torch & that made them go easier.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-18-2004, 08:22 AM   #4
GMC AMI
GMC AMI's Avatar
Good advice, heat is our friend!!!!! Also sound advice penetrating oil and some time.
I found Kroil works better than wd-40. As I am a farmer I deal with rust on equipment
all the time. Good luck with hinge repair, Mike
GMC AMI is offline   Reply With Quote
Old 10-18-2004, 09:50 AM   #5
MOTHERTRUCKERS
We put them in a vise and heat them with a torch and knock the pins out with a long carriage bolt.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 10-18-2004, 10:44 AM   #6
John Fabris
TOTY 2006
John Fabris's Avatar
I had to use a press to get my pins out. Tried using a hammer and punch, just broke the punch....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
