Old 10-18-2004, 01:59 AM   #1
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
PCV and Breather or Oil and Breather?
which do i need to get for my valve covers? PCV valve and Breather caps or oil and breather caps?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 10-18-2004, 06:47 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You need a PCV valve in one cover and some type of breather on the other cover.
Old 10-19-2004, 01:37 AM   #3
Smokin72on20s
Ebay Junky
why PCV?
Old 10-19-2004, 02:16 AM   #4
68LSS1
68LSS1's Avatar
Some people don't like running their stuff without a PCV system. It's to help the piston rings to keep a good seal due to pressure getting past the rings and pressurizing the crankcase. The pcv system keeps this pressurization from happening. A vented breather will do this also but it will not create a small negative pressure for this. A very high percentage of this blowby is unburned fuel so it can be reintroduced. Personally I am not a fan of either so I usually retain somewhat of the stock set up but modifed to look better. And sometime I go with the breathers. The bad thing about the open breathers is they allow moisture inside the engine. When I want to go the breather route I get a little valve from one of the race car or hot rod shops that allows positve pressure from the crankcase out but doesn't allow anything in. It's basically a check valve. You can get them with weld on or bolt on bungs and your breather mounts on top of this. But to specifically answer your question I would run definately vent both covers somehow and have a oil fill cap on one.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
