Old 10-18-2004, 10:37 AM   #1
cochino12
It followed me home?
cochino12's Avatar
Only blows hot when moving?
So I finally got my truck to blow air through the defrost and not just the floor vent but now it will only blow hot air when the truck is moving. At a long stop light the air goes from hot to cold and then will warm up again when I start moving again. Any ideas of what is wrong? Thanks
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 10-18-2004, 11:02 AM   #2
beaterC10
I would check the coolant flow. Could be low coolant, tired water pump, or faulty thermostat. Might see how it behaves when the truck is stopped and you accelerate the engine. Sounds like you aren't moving enough coolant through the heater core at idle.
beaterC10 is offline   Reply With Quote
Old 10-18-2004, 01:34 PM   #3
ocbaud
Garage Queen Material
mine is the EXACT opposite. if i were to warm my truck up for 10 minutes in the morning, the heater would be nice and warm and perfect. as soon as i start driving, and even worse, get on the highway, the heater starts blowing out a lot colder.
i've got a 180 tstat in there.
ocbaud is offline   Reply With Quote
Old 10-18-2004, 02:10 PM   #4
Devil'S Ride
Hey, I understand your problem as well. I fire the truck up let it get to operating temperature, and on cold or cooler days, I have NO heat at idle thru about 2600 rpm. If I am on the free way, turnin about 3000, then I have warm air. not hot, just warm. if it is warm or hot outside, I have really good heat. I flushed the heater core both reverse and forwards, replaced heater lines, an coolant. still no improvement.
I think mebbe it is because at free way speeds I am forcing more air thru the system than at idle? I am unsure....any help or ideas someone has would be appreciated I know that.....it is starting to snow here an havin no heat sucks.....
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 10-18-2004, 08:16 PM   #5
loweredd
www.loweredd.com
loweredd's Avatar
cochino12, I had the same problem on my 79 Impala, only with the air conditioning. It was a broken vacuum line at the reservoir ball. I would check all the vacuum lines in the system.
loweredd is offline   Reply With Quote
Old 10-19-2004, 12:53 AM   #6
1976K5CHALET
1976K5CHALET's Avatar
The problem is a really easy fix...i had the same probs in my 79 years ago when i lived in phx...if your heater line is hooked up to the waterpump...you need to move that fitting to the intake manifold...and then the problem will be solved...
Any plans for Blazer Bash or EJS in 2005?
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 10-19-2004, 10:25 AM   #7
cochino12
cochino12's Avatar
DW
I'll have to check that, thanks
loweredd: All the lines are new, thanks for the help
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 10-20-2004, 02:08 AM   #8
Devil'S Ride
hmmn, guess I'll give that a shot.......wonder why I never noticed that before....must be from when I swapped in the big block....thanks for the ideas....
The Devil
Old 10-20-2004, 05:24 AM   #9
bigd65
bigd65's Avatar
I think I would try the VACUUM BALL that stores the VACUUM for the vents. I would probably bet that it has a leak or the IN-LINE CHECK valve for the VACUUM BALL is eather missing or defective.
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
Old 10-20-2004, 02:22 PM   #10
Devil'S Ride
well I know my vents move, I can get transfer of air, and I know the temp vent moves because of the difference in air pressure (more pressure when on cold than on hot)
I also looked and the 5/8 inch heater hose goes to the water pump, the 3/4" goes to the radiator. So if I move the 5/8 to the intake will that solve my problems? an will it cause any difference in engine coolant temp. I just dont want to switch the lines, and then have somethin go south on me.
TIA
The Devil
