The distributor that was in my '72 when I bought it has the coil in the distributor cap. Is that one of the HEI units? Which of the HEI units is best, the coil in cap type, or the one with a separate coil? Can the coil in cap unit be changed to a separate coil type by replacing the cap with a different type?
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
Professional Grade
The in cap HEI units are extremely good units, much cleaner install too, in my opinion
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
You can get a convert a cap to use a seperate coil!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Still drivin' a Rat Rod
You can also get aftermarket incap installs too,and move up to an accell or mallory,or whatever coil.Like This one
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
All good information. Thank you much.
