Old 10-18-2004, 11:52 PM   #1
skokie
skokie's Avatar
Brake question
I added a booster to my 68 1/2 ton. Its got drums in the front and back. I noticed tonight that when I push the brake pedal down the brakes dont start to work until about 2/3rds the way down. Is this normal or do I need to adjust the rod or brakes themselves?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 10-19-2004, 12:05 AM   #2
skokie
skokie's Avatar
Forgot to put this in. I have checked the fluid and it is fine.
68 build thread
Old 10-19-2004, 12:19 AM   #3
skokie
skokie's Avatar
I pulled the master off of the booster and noticed the black rupper piece was kinda crumpled up. It fell off when I pulled the master out. How is this piece supposed to go back on?
68 build thread
Old 10-19-2004, 06:56 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You don't need the rubber piece anymore. It's used for when you are bolting the master cylinder directly to the firewall without a booster.
Old 10-19-2004, 07:45 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
It sounds like your brake shoes could use an adjustment. You can get a better pedal than that by cranking the shoes out closer to the drums.
I like drum brakes but an occasional adjustment is something that needs to be done with these. I'd get a can of brake cleaner and clean 'em up while your in there too.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-19-2004, 11:25 AM   #6
skokie
skokie's Avatar
Tx Firefighter I will remove that tonight.
Bobs 409 I know that its a star bolt that you have to adjust do you turn it to the left or right to tighten the brakes. Never done this before.
68 build thread
Old 10-19-2004, 02:34 PM   #7
bobs409
bobs409's Avatar
That's it but it turns upward or downward. To move the shoes closer to the drum, turn the wheel downward. (when looking at it from the front)
There should be a slot in the brake drum so you can put a screwdriver in and turn it. Spin drum to check. I usually stop when there is some contact. You don't want too much contact though, just light.
Bob
Old 10-19-2004, 02:39 PM   #8
skokie
skokie's Avatar
Bobs409,
Thanks for the info. Truck is going to the tranny shop tonight for the 400 turbo rebuild so I will do this wen I get the truck back.
68 build thread
Old 10-19-2004, 03:28 PM   #9
mdazb
mdazb's Avatar
Can you use the same master cylinder when adding a booster? I heard the a different MC was needed.....
72 C10 SWB 350 Work in progress
98 HD Fatboy
09 HD Heritage Softail
05 Honda Element
mdazb is offline   Reply With Quote
Old 10-19-2004, 03:54 PM   #10
53burb
53burb's Avatar
I am planning on doing this to a '69 Burb. Is it really beneficial w/o converting to front drums first?? Any suggestions before I do this??
53burb is offline   Reply With Quote
Old 10-19-2004, 04:20 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
On most vehicles, you do indeed need a new master cylinder. however, the P/N for manual and power master cylinders are the same for these trucks.
I'm willing to bet that when you adjust your deums, you'll still have freeplay in the pedal. If so, you'll need to adjust the pushrod.
Did you hook the rod on the pedal to the other hole?
Old 10-19-2004, 04:55 PM   #12
skokie
skokie's Avatar
Longhorn Man
What other hole are you referring to?
68 build thread
Old 10-19-2004, 05:14 PM   #13
Longhorn Man
From what I have read on here (never done a power conversion myself) there are two holes on the arm for the brake pedal. Moving from one to the other chainges the amount of leverage you are using to apply the piston movement in the master cylinder.
I'm 99% positive you are supposed to move the rod from one hole to the other when adding a booster.
Anyone else...am I remembering this correctly?
Old 10-19-2004, 05:20 PM   #14
rodnok1
rodnok1's Avatar
Yea I think you are correct Longhorn Man, sounds just like the problems I had when converting to disc brakes, I had to move the linkage at the brake pedal.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 10-19-2004, 05:57 PM   #15
skokie
skokie's Avatar
Nope didnt do that. Ok where is this hole located on the brake pedal? Anyone got a pic?
68 build thread
Old 10-20-2004, 12:02 AM   #16
skokie
skokie's Avatar
Well I started digging through the factory assembly manual and it looks like there is two holes. Heres the page from the assembly manual.
68 build thread
