10-19-2004, 03:16 AM | #1 |
Just Don't Stop!
Hot drag radials and stock Gov-Lock rear = BOOM
This is what I did on motor tonight LOL. Launched it easy took it to 6200 and slammed 2nd gear. I thought I left a pile of something behind me. Good thing I was only a few blocks from home. I didn't feel like pulling the pan but it definatly grenaded the locker, put a nice hole in the diff cover and it wouldn't move an inch in just free spins the drive shaft.
Usually trucks pull Camaros. Not tonight hahaha. Actually it's not funny. Anyone got a detroit for sale?
1968 C10 build in process TT LSA/6L90e/9" |
10-19-2004, 03:43 AM | #2 |
Member since 2000
it's all part of the game, i bet you still got a grin out of it.
10-19-2004, 04:04 AM | #3 |
Just Don't Stop!
I'm kinda surprized it lasted this long!
10-19-2004, 10:55 AM | #4 |
14.1 @ 96MPH
Yeah, and it's usually the LS1 Camaros that scatter the rear end all over the place...nice work!
Project1970 - LS1 Swap Complete! |
10-19-2004, 11:11 AM | #5 |
There were 2 different gov-locs that I know of. The first one they came out with was junk. The second one was better junk. I had one in my 12 bolt for several years (better junk) and it lasted until I got rid of the 12 bolt and went to 3/4's. It seen a lot of mud pits and off roading but I wasn't really into hole shots.
10-19-2004, 11:28 AM | #6 |
"Trucks with Class"
Gov Locs are built to handle S10s.
10-19-2004, 11:54 AM | #7 |
Some of the drag racers I know affectionately refer to them as time bombs
Saskatoon, Saskatchewan Canada |
10-19-2004, 12:08 PM | #8 |
or my favorite term... junk lock
yeah, but how's it wheel? |
10-19-2004, 02:59 PM | #9 |
Just Don't Stop!
hahaha. Couldn't agree more.
10-19-2004, 04:35 PM | #10 |
Were you at one our local tracks?
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
10-19-2004, 05:22 PM | #11 |
Just Don't Stop!
Naw I was just "testing" out these new BFG drags around the block. They obviously hook alot harder on the street than my M/T ET streets did. Course they are pretty much monsters at 325/50R15's...
10-19-2004, 06:55 PM | #12 |
The Gov-lock usually works just fine. The problem is that when you get a lot of tire spin and a lot of torque (with a 10 or 12 bolt) when the locker locks up it breaks the carrier bearing cap bolts and then all hell breaks loose.
Tim |
10-19-2004, 07:08 PM | #13 |
Just Don't Stop!
well mine broke with NO tire spin and with a hard shift into second!
10-19-2004, 07:16 PM | #14 |
I have never seen one grenade the main caps. but I have seen a ton of them explode the "clock works" crap inside. This inturn goes through the ring and pinion, bearings, etc.........
I suppose you could get a big enough piece going through all of this to pop the main caps, but I have never seen it. It certainly wouldn't be the start of the equation. Gov-Locs are barely adequate for totally stock vehicles driven nicely. Once you introduce more horsepower, a big foot, and/or better traction in the form of bigger tires, they go away quickly. Actually a stock "open" differential is stronger but you don't get the "posi" effect. BTW, they do NOT actually "lock" as in a true locker type diff. They are a clutch type unit that has a centrifugal mechanism that controls the pressure to the clutches. It is not supposed to do anything until there is a certain amount of difference between the tire's speed from one side to the other. It also only works below a certain speed. Once the unit's RPMs enguage the centrifugal parts, there is no "lock". |
10-19-2004, 07:42 PM | #15 |
here's what you need....
get out your wallet.... Last edited by rage'nrat638; 07-12-2007 at 07:05 AM. |
10-19-2004, 07:50 PM | #16 |
PROJECT 7DEUCE
Bummer on the locker guess it's time for an upgrade, like mark's..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-19-2004, 07:56 PM | #17 |
Just Don't Stop!
Bring you wallet is right! Nice Setup! 9", QA1's, wilwoods, 4 link, wishbone maybe? you prolly got about what 4.5K in that setup? Wish I was a balla like you hehe.
1968 C10 build in process TT LSA/6L90e/9" Last edited by FirstGen; 10-19-2004 at 07:59 PM. |
10-19-2004, 08:01 PM | #18 | |
but....you want to play you got to pay..... |
10-19-2004, 08:34 PM | #19 |
Just Don't Stop!
Couldn't agree more! Looks great. Eventually I'd like to do a similar setup. Be fun to fabricate it all at home too...
10-19-2004, 08:45 PM | #20 |
I agree you may have to lose the 12 bolt with big power but I wouldn't give up my trailing arms for a 4link. I know for a fact that 67 dragtruck has been as fast as I want to go with trailing arms and coilovers(5.32 eighth mile) on a 10.5w slick I might add!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
10-19-2004, 08:57 PM | #21 |
Just Don't Stop!
yeah he's running a 12 bolt too right?
10-19-2004, 09:02 PM | #22 |
just keep in mind that 12 bolt car and truck rear ends are two different beast....totaly
10-19-2004, 09:15 PM | #23 |
Just Don't Stop!
is the car built better or something?
10-19-2004, 09:27 PM | #24 |
o yea....the car 12 bolt housing is much thicker to hold up to the high h.p. of the chevelle's camaro's...all the big block's.....etc....
the truck 12 bolt is whimmpy.....truck's never had high h.p.... used for pulling towing etc..... find a car 12 bolt...they want 500.00 plus for it.... a truck 12 bolt...50.00.... the first rear end i did was a 12 bolt truck rear..... blew that thing to bit's....broke 8 valve spring's in the 638 c.i. when it over rev'ed..... did not ever want to do that again..... here's a pic. of the old 12 bolt...set-up Last edited by rage'nrat638; 07-12-2007 at 07:05 AM. |
10-19-2004, 09:35 PM | #25 |
First gen
He runs a nine inch with 35 spline gundrilled axles!!!!!!!!!!!!!!!!!
