Old 10-19-2004, 02:29 PM   #1
DCRANER
Battery Cables
In process of redoing engine compartment (86 GMC) and original cables are just o/k. Now, I would like to do new ones (side post) but have a question.
Original posi. has two small leads and am not sure if this is required for new ones. I will be doing a single wire Alternator, where I will run a wire down to starter location for a clean look.
So, has someone done a really clean upgrade like this, do I need those additional leads on the cable, etc. I called Letric Limited and they will not even talkto me unless I have a 72 or earlier truck, so is there is good supplier for new cables.
Info. / suggestions appreciated.
86 GMC SWB, DK. BLUE, ZZ430,TH400, 4.11'S, HEADMAN CERAMIC HEADERS, WELD BILLETS, BFG 275 / 60 / 15, 325 / 50 / 15 DRAG RADIALS, FIBERGLASS COWL HOOD, B&M SHIFTER. MSD, MARCH PULLEYS / ALT. / PWR. STEER PUMP, BECOOL RAD., BILLET GRILL & GRANT WHEEL.
DCRANER is offline   Reply With Quote
