Frame question
I may have the opportunity to pickup a 1972 cab and frame complete to the tires but no title. My question is will my 69 body bolt on to the frame without any problems like the steering or brakes? I plan on blasting this frame and either powder coating or using Por15. Thanks for your input.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug |
its all about the +6 inches
Bolt up no problem.
Which would be better to go with the powder coating or the Por15?
all depends who you ask.
I see powder coat flakeing off the chassis of the big rigs in as little as one year. But, if it is a show rig, it'll possably hold up for a decade...and look awsome. Properly applied...I have never seen POR flake off...and it helps prevent rust while powder coat will let the rust build up under it. POR can be done at home with no special tools. POR is probably cheaper Any spot of POR that you have to grind off with grind and feather very well instead of flake off. If you use the chassis black POR, it'll hold up to the UV rays no problem and won't need to be painted over. I'm a little biased though. |
I plan on doing all of the work myself. I am just trying to make it last for sometime not show it. One of those things that when you look at it you can say I did it myself and be proud of what you have done. That and I don't want to spend a fortune either.
67 is sold
I plan to roll a 72 Frame/chassis under my 67 when it's all said and done.
Powdercoating is the way to go if you can afford it. If it is flaking off, it wasn't prepped/applied properly. Por15 is a great product, but I hear from many sources it fades/discolors over time. When coating metal with anything, proper prep is a very important part of the process ![]() |
Navel Inspector
So for protection which is better? I don't mind the fading and discoloration so much as I would the flaking. I'd prefer powdercoating though. But honestly unless you are able to do the work yourself how do ya know if it was done right and how long do you have to tell?
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
67 is sold
Powdercoat is 'baked' into the metal. Painting is applied to the surface. I'd go with powdercoat for durablity.
You can still paint over scratches, etc if they occur. Regarding getting it done right, just like any other work, get local opinions and referrals. |
#9 | ||
I'd say powdercoat if you can afford it. If the job is done well you shouldn't see any flaking. I had the wheels on my GMC powdercoated 6 or 7 years ago. No chips, no flaking or any other problems. Used paint prior to that it. It was chipped within a year. This is no show truck so it's been driven (beat on?) almost daily.
Life is Good !
I powder coated mine :p I will be powder coating all my frames from now on as well
![]() ![]() ![]() It cost me right around $700 for the frame alone ! everything in the pictures below is powder coated ![]() Good luck with your project ![]()
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" Last edited by landon4421; 10-20-2004 at 11:39 PM. |
Designated A-hole!
That's a sweet frame landon! Almost seems a shame to cover it with a body.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
