Old 10-20-2004, 02:18 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
window crank access
my window will not crank down efficiently (i have to work it). i tried to get to it by takeing the panel off but its impossible to work on it. can i do this job or will the door have to be taken apart?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 10-20-2004, 02:29 PM   #2
hotrodhomi
hotrodhomi's Avatar
have you tried silicon lube?
hotrodhomi is offline   Reply With Quote
Old 10-20-2004, 03:24 PM   #3
crm318
crm318's Avatar
its not that its unlubed. when i crank it, the wind goes down in increments. i think that the cranke might be missing teeth of its out of allignment. i need to get to it somehow but i have no access
1972 Cheyenne
Old 10-20-2004, 03:47 PM   #4
mhicks
mhicks's Avatar
Mine did that and replacing the window channel felt fixed it.
mhicks is offline   Reply With Quote
Old 10-20-2004, 04:57 PM   #5
crm318
crm318's Avatar
another thing, when i push the lock doen and close the door it still opens. when i close the door and lock from the outside, it still opens
1972 Cheyenne
Old 10-20-2004, 05:28 PM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
My truck does the same thing. I assumed they all did it. Actually quite nice, impossible to lock the keys in the truck.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-21-2004, 02:23 PM   #7
crm318
crm318's Avatar
it must be a common problem. i wonder how it can be fixed?
1972 Cheyenne
Old 10-21-2004, 11:26 PM   #8
jimfulco
It's not broken. They're supposed to do that so you don't lock yourself out. Chevy trucks all did that back then, same as many Ford cars & trucks did. You have to use the key to lock it. I always thought it was mighty strange that you could lock a car without a key, but then I was raised around Fords.
jimfulco is offline   Reply With Quote
Old 10-22-2004, 12:44 AM   #9
LONGHAIR
engine and drivetrain?????????
LONGHAIR is offline   Reply With Quote
Old 10-23-2004, 12:31 AM   #10
crm318
crm318's Avatar
i cant lock it at all. it wont lock with or with out the key.
1972 Cheyenne
Old 10-23-2004, 07:27 AM   #11
Blue Beard
Blue Beard's Avatar
Could be that someone else had the door apart before.
The lock issue could be reinstalled wrong.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-23-2004, 09:55 AM   #12
XXL
Seņor Member
XXL's Avatar
Originally Posted by jimfulco
...but then I was raised around Fords.
I'm sorry to hear that
BTW OP, Suspension forum??
XXL is offline   Reply With Quote
Old 10-25-2004, 09:58 PM   #13
kewlbear
Does the window drop a little when you crank it up or down. If so your window crank gear is bad. Replace it with new one, junk yard one not worth the trouble. You can buy that whole piece (regulator) new for under $75. As for the door thats the way they supposed work, you cant lock it then close it cause it unlocks its self, passenger side same way has to be lock from inside, but if you close it and use key it should lock. If not then something outta whack somewhere.
64 Chevy pickup
tilt,pb, ps discs up front
350/TH350, 72 rearend
auto meter gauges
93 GMC extended cab
trailmaster conversion
kewlbear is offline   Reply With Quote
Old 10-26-2004, 01:54 AM   #14
crm318
crm318's Avatar
yea, its got to be the gear. how do i get access to the regulator? im worried about getting everythig out an not being to get everything back in
1972 Cheyenne
Old 10-26-2004, 02:39 PM   #15
kewlbear
Its not to hard to get out. There should be four big phillips screws in a rectangle pattern, one on top and one on bottom of crank shaft and two more three or four inches down. Make sure you roll window all the way up and wrap some strong tape from inside of window over the door to the outside of window to hold the glass up. Then take crank handle off and then those four screws now the fun part. There should be a small gap in the middle of the metal track on the bottom of the glass, this is where one of the regulator roller has to come thru. Then drop it out and out of your way and do the other roller same way, I think the last roller will go out either end also, been awhile since I done mine. Once you look at it you will see what im talking bout, then once you get it loose from window fold scissors flat and bring it thru the hole in the door, believe it or not it will fit thru this hole, if you hold you tongue right. Anything else I missed guys, its not as hard as it looks. I thought the samething when I first done mine, there no way to get to that out. You should look at new trucks with power window motor on it, makes these old truck look easy. Maybe this info will help, or somebody on here can add anything I missed. Like I siad been awhile since I done mine, I've done couple newer trucks since.
64 Chevy pickup
auto meter gauges
93 GMC extended cab
Old 10-26-2004, 03:14 PM   #16
crm318
crm318's Avatar
thanks, ill give it a shot
1972 Cheyenne
Old 10-30-2004, 12:59 AM   #17
jakeslim
Premium Level Member
jakeslim's Avatar
I've done a few of these(3), it is not that easy to get the mechanism free. Sometimes it will slip right out of window track and sometimes, like the last time i did it, it took alot of arm scraping to manuever inside the door. Anyways, I alway grease the gears and mechanism with lots of heavy duty bearing grease so that it holds. Sprays are short lived and require more frequent lubing in my opinion
jakeslim is offline   Reply With Quote
Old 10-30-2004, 06:43 AM   #18
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Moving this to the 67-72 section.
