Old 10-20-2004, 03:46 PM   #1
Ric83
Ric83's Avatar
Best place for new distributor?
My dad's truck seems to be running kind of rough lately. After looking at it and asking some questions on here, it seems like he is in need of a new dist. What would be the best place to find one. It has an stock 305 and he by no means is lookingn for anything way out there. Just wants something origional to replace it w/. Where would be the best/cheapest place to find one? Anything in perticular to watch out for? Thank to all in advance.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 10-20-2004, 04:03 PM   #2
CHEVYE
my gas saver
CHEVYE's Avatar
if it is an hei they are easy to get ahold of. grab one at a junkyard/ebay/or here. shouldn`t be more than $40 used or so.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 10-20-2004, 04:06 PM   #3
Ric83
Ric83's Avatar
Would a used one be ok? Should we replace anything in it before install?
Ric
Here she is
Old 10-20-2004, 04:34 PM   #4
RockHQ
ROCKET POWER!
RockHQ's Avatar
I don't think a junkyard distributor is the way to go if one wants ultimate reliability. The junkyard specimens have the same faults, sticking advance weights, worn out springs, loose main shafts&bushings, shims and so on. Not to mention if the magnetic pick-up, star wheel, coil or module are broken. It gets real old having to replace parts every few months, and by the time you rebuild a HEI distributor properly yourself buying each individual component separate it will have cost you far more than a rebuilt or an aftermarket dizzy.
Plus you don't get a warranty for the whole dizzy, just individual parts.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 10-20-2004, 04:36 PM   #5
RockHQ
ROCKET POWER!
RockHQ's Avatar
Remember, even the newest GM stock-issue HEI distributor is 18 years old now.
Old 10-20-2004, 05:15 PM   #6
cliffsta
Stepsides RULE
cliffsta's Avatar
How does one know if the distributor is bad? I go through distributor cap, rotor, etc, a tad more than i here necessariy, and i think my timing is off (i dont have direct access to a timing light). is there any way to know if its bad? Should i call my cousin and tell him to pop by with his timing light? Just kinda curious...
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-21-2004, 08:11 AM   #7
Ric83
Ric83's Avatar
How much can we expect to pay for a good rebuilt one? Best place to look for one?
Well in the case of my dad's truck, it has no get up and go. Seems like the mechanical advance is on it's last let or something. Also, when I put a timing light on it, the line would jump every few seconds.
Ric
Here she is
Old 10-21-2004, 03:52 PM   #8
CHEVYE
my gas saver
CHEVYE's Avatar
i would buy an aftermarket before rebuilding too.
71`SWB, project
ebay feedback
Old 10-22-2004, 12:00 AM   #9
jimfulco
Rebuilt ones run a little over $100. Here's a new GM unit for $185:
http://www.sdpc2000.com/catalog/923/...st-Housing.htm
jimfulco is offline   Reply With Quote
Old 10-22-2004, 09:46 AM   #10
Ric83
Ric83's Avatar
I found a few of these, but they seem to say they fit up to '82??
http://cgi.ebay.com/ebaymotors/ws/eB...category=33690
Will in not work on his 83? What is the diff?? Where else could I find a rebuilt one?? Tried a few major on line places, but seems like they cost a lot. Will I not be able to find anything under ~$180?
Ric
Here she is
Old 10-22-2004, 09:56 AM   #11
RockHQ
ROCKET POWER!
RockHQ's Avatar
He claims it will fit Olds, Buick and Pontiac V8s too. I don't see how thats possible, for example on an Olds V8 the distributor doesn't go through the intake manifold at all so the mounting flange is a lot closer to the drive gear. Plus the distributor rotates counter-clockwise on an Olds.
It should however drop right into a SBC.
Old 10-22-2004, 10:19 AM   #12
ocbaud
Garage Queen Material
i believe that in 83' they starting using esc(electronic spark control). it will advance/retard the timing whenever there is detonation.
that dizzy would work perfect in his engine, but he would have to adjust the timing himself from now on.
ocbaud is offline   Reply With Quote
Old 10-22-2004, 10:38 AM   #13
Ric83
Ric83's Avatar
What do you mean he would have to adjust the timing himself from now on?? You mean like it would need to be adjusted rugularly?
Ric
Here she is
Old 10-22-2004, 11:25 AM   #14
Slonaker
Insert Witty Text Here
Slonaker's Avatar
The ESC engines use a knock sensor, I assume to retard the timing when it needs it. An earlier distributor without ESC will work in his engine, and is preferred by many people. I know that when the time comes, my ESC distributor will be replaced with an older, simpler HEI.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-22-2004, 12:59 PM   #15
1986Silverado
What I drive
1986Silverado's Avatar
AutoZone list one for an 83 1/2 ton p/u with a 305 for $104.99 with a $30 core charge. I'm sure it's a rebuilt unit but comes with a limited lifetime warranty. Also not sure how complete it is, may or may not come with the cap and rotor
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 10-22-2004, 01:18 PM   #16
Ric83
Ric83's Avatar
Yeah, I did see a couple listed at that price, but the came w/ no cap, rotor, coil, ect...
Ric
Here she is
Old 10-22-2004, 02:55 PM   #17
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
I would go out and get a decent core dizzy (tight bushings) and rebuild it yourself, using new springs, pickup coil, etc. At least when you buy the parts yourself, you have some control over the quality. Those new "junkers" on e-bay, as well as the ones you buy at Autozone/Checker are built with the cheapest of the cheap parts.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 10-22-2004, 04:33 PM   #18
swervin ervin
You get what you pay for
swervin ervin's Avatar
I agree with Marc. If I didn't want to lay down the bucks for a new GM unit, I sure wouldn't buy one from Autozone. Junk is a great word for what they would sell you. Taiwan junk.
If you don't want to get a new GM unit, find a good core at the junkyard and rebuild it with all new bushings, springs, etc.
Depending on what your plans are for the truck, I would go with a new GM unit myself. A cheap distributor will put you on the side of the road in a New York minute.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 10-22-2004, 04:53 PM   #19
C&C Chevy
C&C Chevy's Avatar
What about a Proform unit? They're GM authorized. (whatever that means..)
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 10-22-2004, 05:32 PM   #20
ocbaud
my chevy perfomance alum. valve covers are actualy proform, and they cracked.
i myself, dont think i would buy proform performance parts.
Old 10-22-2004, 05:36 PM   #21
swervin ervin
Proform stuff is pretty sorry also. The GM authorized thing only means they are authorized to put GM labels and names on their products. It doesn't mean they are authorized as good from GM.
Old 10-22-2004, 05:44 PM   #22
C&C Chevy
C&C Chevy's Avatar
I thought that would get a rise out of some of you guys.
Robert
Current:
Past:
Old 10-22-2004, 05:56 PM   #23
cliffsta
Stepsides RULE
cliffsta's Avatar
OR you could find a whole core unit and send it to LMC or even take it to your dealership and have them rebuild it. If you send in a core to LMC they send you a remanufactured unit, not neccessarily the same one you supply them with. BUT my vote is along with the other guys', go with a new GM unit or rebuild a GM unit. Overall, GM distributors are pretty solid as compared to Found On Road Dead.
Old 10-23-2004, 09:06 AM   #24
RockHQ
ROCKET POWER!
RockHQ's Avatar
Rebuilding a junkyard distributor isn't the cheap way to get a "new" GM HEI.
I used http://www.rockauto.com/ 's online catalog, and priced together all the parts to rebuild a HEI. I was not able to find the rotor shaft bushings however. I chose AC Delco parts when possible but roughly 50% of the parts were Standard Motor Products (=made in Taiwan cheaper than ACD), and if there were several options priced differently i chose the middle priced one.
Remember, this doesn't include shipping/handling:
-Module (ACD#1906) $30.79
-Cap (Standard #DR450X) $17.46
-Rotor (ACD#D448) $05.36
-Coil cover (ACD#1875960) $07.10
-Pick-up felt pad, washer(Standard#DG53) $04.23
-Pick-up coil (ACD#1907) $29.99
-Adv. bushings (Standard#DG54) $07.15
-Adv. weights (Standard#DG50) $03.61
-Vac. advance can (Standard#VC234) $10.67
-Capacitor w/ harness (Standard#RC4) $11.94
-Ign. coil (ACD#D504A) $42.79
-Ign coil gnd strap (Standard#DR31A) $01.26
-Mounting gasket (Fel-Pro#70194) $00.69
Total: $173.04
And we still haven't touched the rotor shaft bushings.
Old 10-23-2004, 09:35 AM   #25
cochran63
cochran63's Avatar
I actually have a new proform distributor on the shelf. It is junk. I put it in my motor and it would surge and buck and then in a few minutes it would run great and then back to surging. I took it out and called them. They said to replace the module and they would reimburse me the money. I did it and it did not help. I tried to send it back to them but they just kept trying to diagnose problems over the phone. so i went to the junkyard ang got a good one for $25.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
