Old 10-20-2004, 04:29 PM   #1
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
Cant put my tailgate on
how do you put your tailgate on? i cant get it to fit, i cant get both sides to fit into the trunions. i have a 72 fleetside by the way.
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 10-20-2004, 04:43 PM   #2
sactoC10
71 DELUX
sactoC10's Avatar
stock gate or aftermarket?
I just put mine back on a couple of weeks ago. Got some milk crates and a blanket, stacked them up at the rear, put the blanket on top, scooted the gate into place while resting on them, trunions inserted with ease and started bolting into place. Are the trunions the right ones for the gate? Maybe and earlier model year?
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 10-20-2004, 05:52 PM   #3
my new 72
faster, faster, faster
my new 72's Avatar
Try putting the trunions on the gate before you bolt them on the bed.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 10-20-2004, 07:54 PM   #4
Harold Shepard
Use some tape to hold the trunnions in place on the gate and the tailgate should slide into place. lay out the 9/16 wrench and four bolts -2 for each side and get some help to hold the gate in place 15-20 minutes tops if the box is square and in good shape.
Harold Shepard is offline   Reply With Quote
Old 10-20-2004, 08:27 PM   #5
Smokin72on20s
Ebay Junky
its an reproduction, but i dont think it is any different from the original ones?
Old 10-20-2004, 08:57 PM   #6
dwaite72lnghrn
The way I normally do it is bolt the one side on, Hold the other in my hand, set the tailgate on the bolted 1, tilt the gate at an angle and slip the other on in the channel. Then I hook on the gate limit bars, the tighten the remaining bolts snug but not tight, close the gate position gate for alignment, and tighten bottom bolts both sides. open gate tighten upper bolts. always worked for me.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 10-20-2004, 10:10 PM   #7
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
if you have a welder you could cut a notch in the tailgate and then cut 2 of the sides flat on the trunions and weld a falt bar in. then its a quick release like the newer trucks
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 10-20-2004, 11:17 PM   #8
purple gas
what dwaite said,, and don't drop it on your foot,,,, trust me on that.
purple gas is offline   Reply With Quote
Old 10-22-2004, 12:46 PM   #9
Richard Dobson
dwaite what a perfect description of what to do. When with the instruction video be available. How do you make the tailgate close properly when one side hits at the top right and leaves a 1/2" gap on the top left instead of closing flush on both sides. All the gaps are OK it just won't close against the bedsides flush.
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 10-22-2004, 06:10 PM   #10
dwaite72lnghrn
Take a square on the bed frame right behind the tail gate to the sides and make sure one side isn't spung out, They have a tendency to tear at the welds right at the bottom. If it is good, Then I would loosen the right side bolts and see if it will slide up a touch then tighten. Then loosen the left side and see if it will lower a touch then tighten.
2009 HHR aqua blue
Dave & Jeanne
