Old 10-20-2004, 08:38 PM   #1
C&C Chevy
C&C Chevy's Avatar
Have to replace door locks.
Somebody tried to break into my truck by jammin a screw driver into my drivers side lock. All I have is a 5 year old Sony CD player that they would've got $5-10 at a pawn shop. Anyway how do I change the locks out?
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 10-20-2004, 09:59 PM   #2
Blue Beard
Blue Beard's Avatar
Fairly easy to change out....
Remove the handles, arm rest, and panel.
The locks are held in place with a flat spring piece that can be pulled out. Be sure to put it back in with the flat side to the door.
Be a good afternoon job.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-20-2004, 11:23 PM   #3
RockHQ
ROCKET POWER!
RockHQ's Avatar
You don't need to change both door locks, just the broken one. Have a locksmith match the new lock cylinder to your existing key.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 10-21-2004, 02:16 AM   #4
kballan
kballan's Avatar
Yep, pretty easy to do. Should be able to get it done in an hour or 2. If that.
Kent Ballan
ANY MAN CAN BUILD A TRUCK, BUT IT TAKES A REAL MAN TO CUT ONE UP!
kballan is offline   Reply With Quote
Old 10-21-2004, 06:50 AM   #5
Blue Beard
Blue Beard's Avatar
Generally when purchasing a new door lock they come in pairs.
Rekeying one at a locksmith would cost more than its worth. I use to do locksmith work and saw some of the prices charged.
Unless you want the Ignition and the doors to be the same key.
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 10-21-2004, 10:11 AM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I agree. I bought a new set of door locks with a matching cylinder for the ignition. It will allow me to have one key for the doors and ignition. I think the set was about $25 from Chevy Duty. I seriously doubt a locksmith would re-key a lock any cheaper than that.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-21-2004, 09:30 PM   #7
C&C Chevy
C&C Chevy's Avatar
How much are the locks from GM? I searched the usual GM parts websites and couldn't find door lock cylinders. Are the Chevy Duty ones "GM"? They're pretty cheap at $17 for the set. Found a set at NAPA under the "Echlin" name for $30.
Robert
Current:
Past:
Old 10-21-2004, 10:15 PM   #8
Slonaker
Slonaker's Avatar
I don't know who makes them, but they are probably not real GM parts. They come in a clear plastic bag with no markings of any kind.
Slonaker
Stock '01 Silverado
Old 10-21-2004, 10:21 PM   #9
Destructo
I pulled my lock cylinder and had a locksmith make a key for the cylinder, cost me like 7 bucks I think, pulling the cylinder was a 15 min job too. Peice of cake, pull the panel, disconnect linkage and slide the spring clip out and your done.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 10-22-2004, 12:38 PM   #10
rolson1039
Last time someone tried that on my GM car i popped out the cylinder and brought it along with my key to the locksmith and he charged me $12 to reubuild it and that was in NYC... even if he charges you $25 thats still cheaper than popping apart TWO sides to make the doors keyed alike.
The other alternative is to go junkyarding and find a GM Vehicle with the door key still in thre with an external cover kind of key cylinder. Theryere all basically the same its the piece thats held on the back of the cylinder that is usually different but they all pretty much interchange
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 10-22-2004, 01:19 PM   #11
C&C Chevy
C&C Chevy's Avatar
One reason I'm going ahead and replacing both is the orignal key is getting pretty worn and hangs up alot. Thanks for the info sounds like an easy job. I'll git'er down when the rain lets up around here.
Robert
Current:
Past:
Old 10-22-2004, 04:03 PM   #12
cliffsta
Stepsides RULE
cliffsta's Avatar
All this talk about theft recently gave me the worst nightmare last night: These gangsta black thugs who had no business wanting my truck carjacked me, then i stole Red back but it was toast. I crawled outta bed at 3AM this morning to go check everything was all right......
If i get robbed tho i deserve it; half the time i dont even roll the windows up. My truck looks so bad most crooks wouldn't bother. Bad paint and poor body = theft deterrence
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-22-2004, 05:06 PM   #13
C&C Chevy
C&C Chevy's Avatar
I've done that before too.
Robert
Current:
Past:
