Old 10-21-2004, 04:43 PM   #1
cliffsta
Stepsides RULE
cliffsta's Avatar
Carb rebuild kit
Based on the advice I've received here, I've decided to spend 50ish bucks to rebuild my carburetor rather than spend 250 bucks on a 50/50 chance with a Tawaiin rebuilt unit. What kit do you guys recommend? I want one that includes the accelerator pump and any other moving/working parts inside, not just the gaskets. Do the kits autozone, etc, sell include the accelerator pump? Any imput is appreciated.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-22-2004, 04:05 PM   #2
cliffsta
Stepsides RULE
cliffsta's Avatar
TTT
I know FOR A FACT several of you guys rebuild your carbs. What kit do y'all use?
Old 10-22-2004, 04:20 PM   #3
76cheyenne
No more
76cheyenne's Avatar
There has been so many carb threads I don't think people like talking about them any more. lol I couldn't tell you were or what rebuilt kit to get because I need to do it myself.
1976 Chevy K10 CheyenneTrue Duals with glasspacks and cutouts, Blacked out tails, Rockford Fosgate H/U with 2 Sony Xplode 6x9s and 2 8" MTX Subs with a Alpine Amp. New front clip in primer. For Sale $2000 obo
76cheyenne is offline   Reply With Quote
Old 10-22-2004, 04:21 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
To tell you the truth, I've bought a bunch of kits for Q-jets over the years from several different makers. There isn't much difference in quality from one to the other. The ones I've seen and used all looked about the same.
It will come with every thing you need to rebuild it but they don't come with floats. The new floats are not the hollow bronze like the old carbs used to have. They would get pin holes in the them fill with gas, causing the float to drop and use too much gas. The newer float are solid and don't get gas soaked. You wouldn't really have to replace these floats, but if you do, you will have to buy it seperate. I think they are about 8 bucks by themselves.
Don't forget to buy some carb dip cause the cleaning is 90% of how good the rebuild will be. Check the throttle shafts to see if they are worn excessively. Also check the air horn to see if it warped from over tightening.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 10-22-2004, 06:40 PM   #5
1972C10
1972C10's Avatar
Thorsen makes a good kit.. And i suggest getting a brass float Those neoprene ones are junk
Ill tell you how to test them thou Place the float on the floor and then stomp your foot on it If it leaves a wet spot its bad
1972C10 is offline   Reply With Quote
