coilovers?
anybody make a coilover kit for our trucks?
you can use the qa1 kit from jegs I run their shocks with jegs mounts.h
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
![]() Join Date: Nov 2003
How is the ride with those?
was it a direct bolt up? or was there a lot of measuring?
the reason i got coilovers in my head was an old issue of classic trucks from 97. there's an install of a classic performance products kit in a 67-72. now i cannot find them. i love the ride of coilovers in my mustang. i figure they would be good in a truck also |
I think you're looking for Classic Performance Products. They have two kits, one with a 3" drop and one with a 4 1/2" drop. Go here scroll down a little and you'll find them. The instruction are available online from their site. I was originally going to go with one of their kits and then decided I needed something more. Haven't heard anything but good about the company.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
#6 | |
However I'm thinking of changing it over to the set-up like djracer's. So that I have more adjustment.
1969 Chevrolet SWB Stepside 1959 Chevrolet apache * Sold 1967 Prostreet Chevy SWB Fleetside *Sold 2014 1/2 ton Crew Cab Chevrolet 4x4 |
I love the ride and driving with the coilovers! I don't think I could do heavy hauling or towing with the springs on mine but you could run a stronger spring! It was definatly not a bolt in! It was more like a weld in. I want to get the rear of my truck a little lower so I'll address that while the bed is off! We installed the shocks with the bed on but If I had it to do over I would have pulled the bed!
#8 | |
![]() Join Date: Jun 2002
Here's the install...http://www.classicperform.com/tech_a...coil-overs.htm
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
primed - so you cannot adjust your coilovers? thats one of the main reasons i wanted them. that and the smooth ride
i see that i can just order the brackets. then just order an adjustable qa1 coilover kit like djracer, correct? the best of both worlds, adjustability and easy install. |
#11 | |
primed - so you want to be able to adjust the attachment point back and forth along the frame...correct? what's that gonna do?
#13 |
primed 67
I thing I have 200 pound springs but I'm not sure! I can call jegs and see what I bought if you need me to.
#14 |
how much adjustability do you guys have?
#15 |
ran out of money
I am a little lost guys.... what is the main advantage of having coil overs over haveing the stock set up? is it for racing or comfort of ride?
Thanks Rat
Modify everything, leave nothing alone!~ ![]() ![]() |
#16 |
they ride good, hook great, and my shocks are adjustable for firmness
#17 |
#18 |
I don't have adjustable shocks with mine but right now I have about 4-1/2" of adjustment up or down.
#19 |
Mine have 10 or 12 clicks of adjustment to change firmness! Mine are actual drag shocks! If I drove it allot I'd run the street versions because the ones I have are meant for the street they have rod ends instead of rubber bushings.
#20 |
gotcha. just what i wanted to know
