No more
Fuel Inlet nut on carb Question
I just changed my fuel filter and when I put the fuel inlet nut back in the carb its like it won't go back right. I have it tightened down enough and I even put Blue silicon gasket on it and it still leaks like a waterfall. What is wrong. I have screwed it and unscewed it to make sure it is right and it is. What should I do?
1976 Chevy K10 CheyenneTrue Duals with glasspacks and cutouts, Blacked out tails, Rockford Fosgate H/U with 2 Sony Xplode 6x9s and 2 8" MTX Subs with a Alpine Amp. New front clip in primer. For Sale $2000 obo |
leak
hair line crack maybe? does it thread in and out easily or is it maybe cross theaded?? just a couple of thought's..
huh?
![]() Join Date: May 2000
I think some, if not all quads had a plastic washer of some sort that goes on there. Just an idea for you, if it's a quadrajet.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
ROCKET POWER!
Yeah, Q-jets have a plastic washer at the end of the threads on the inlet adapter. Don't remember the size but you could try your local parts dealer.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
No more
Ya it is the q-jet and there is no washer on mine. So I should try and get this and this will work better then the blue silicone?
