20' Daredevil (Ret)
![]() Join Date: May 2003
For quite some time now, I have had a noise I can't really describe. It's road-speed related, kind of a soft ratcheting, whirring sound that comes & goes, presumably with each rotation of the front driveshaft (in 2WD, hubs out - normal "relaxed" rotation from front axle drag).
I pulled out the front driveshaft and the noise is gone, so I'm guessing it's the double carden joint, though I can't see anything obviously wrong. Can the driveshaft be rebuilt (replace the joint), or do I need a new driveshaft? If I need new, can anyone recommend some good sources? Thanks, guys (& gals!) ![]()
Those joints are rebuildable. I have never rebuilt one myself but Ilve taken the driveshaft into a shop and had it done on my pickup and suburban.
Call around to shops and get a price quote. Bill |
My truck was so bad when I got it, that the front driveshaft smacked the exhaust pipe when I put it in 4wd, and it sounded like a machine gun. I got the cardan rebuilt, driveshaft balanced, and some cheapo spraypaint, for $100-$125 or so. I replaced the ujoints myself.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
I like cheese
LMC sells a rebuild kit for that joint. Around $30 I believe. I've had them apart and theres not much to them however I'm usually short on time and need my front driveshaft right then so I've never rebuilt one. I just put another driveshaft in. I try to keep about 4 extra front shafts on standby.
user # 2756
![]() Join Date: Jun 2001
Just rebuilt mine. Cost about $80 for the parts. 3 u-joints and centering yoke. The centering yoke is $65 through lmc, I paid $45 at a local drive line shop(spicer part). The centering yoke has a bearing in it.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
20' Daredevil (Ret)
Thanks, guys. Lacking a workbench, not to mention a shop, I dropped off the shaft at a local shop late this afternoon. They'll replace the double cardan joint and the u-joint, so it oughtta be good for another 33 years!
Funny thing is, today I noticed the noise again, but much quieter ![]() ![]()
I'm not sure I'm reading your original post right but, if the hubs are unlocked, and the TC is in 2WD, the driveshaft should not be turning. Is it possible that one hub is screwed up and not unlocking? That will defininely cause noises from the front diff.
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements. |
user # 2756
I don't have the boots on my shifters on my 71 and can watch the front driveshaft turn slowly. It's the parasitic drag of the gear oil causing it to turn. But any resistance should cause it to stop turning.
#9 | |
20' Daredevil (Ret)
#10 | |
#11 | |
I like cheese
#12 | |
