Old 10-22-2004, 06:41 PM   #1
chipotledude05
Strategery
Talking Flex?
How much do you guys think a '61 4x4 with the original leaf springs articulate? And also, how much would this effect its off-road performance? A friend of mine doesn't put much faith in an old chevy (jeep guy). What do you guys think?
chipotledude05 is offline   Reply With Quote
Old 10-22-2004, 07:05 PM   #2
Blazer1970
Blazer1970's Avatar
Flex is highly overrated, but it totally depends on the type of wheeling that you intend to do.
Blazer1970 is offline   Reply With Quote
Old 10-22-2004, 09:54 PM   #3
Destructo
Here what 3 leaf CUCV military truck springs in the front and stock 6 leaf 1/2 ton springs will do without a sway bar.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 10-22-2004, 10:05 PM   #4
chipotledude05
Strategery
I'm really interested in my truck being an all around good 4x4. I mainly want to stick to trails and less to rocks and mud holes. overall, nothing too extreme, but i would still like to be able to prove a few jeep guys wrong.
wow. that pic definately makes me feel better
Old 10-22-2004, 11:08 PM   #5
Destructo
I used to have Rough Country 4" lift springs front and rear, it flexes better with the stock springs actually.
So, if you go with lift springs choose them wisely, Tuff Country makes good flexy springs and they ride good too. Shackle angle is also important when considering flex, also having the proper bump stops to stop up travel and the right shock setup so everything works together.
Also removing your front swaybar will help your flex out a lot, and with it lifted I didn't notice a whole lot of difference while driving.
Old 10-22-2004, 11:51 PM   #6
1FaastC10
1FaastC10's Avatar
when you're stuck in Michigan and all you have to play in is mud, i can see why you would think that.
1FaastC10 is offline   Reply With Quote
Old 10-22-2004, 11:56 PM   #7
1FaastC10
1FaastC10's Avatar
on my truck i am running a shackle flip on the rear (give 6" of lift) and i am running stock 52" rear springs front and rear on my rig. they should flex pretty good. this pic isnt my rig, but he is running the same setup.
http://www.austink5.net/gallery/albu...1433.sized.jpg
Old 10-23-2004, 01:38 AM   #8
1969 GMC
1969 GMC's Avatar
the 3 red dots are roughly Elkhart, West Olive, and Doylestown (for S & G).
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-23-2004, 01:40 AM   #9
1969 GMC
1969 GMC's Avatar
oh, and as to the original question, stock springs are fine. since your truck is already 44 years old, they should be nice and loose ;-)
if you do need more flex, you can do a spring swap as jeremy suggested.
1969 GMC K2500
1996 Honda Accord
Old 10-23-2004, 08:28 AM   #10
Blazer1970
Blazer1970's Avatar
With this type of wheeling:
#1 - rear locker
#2 - front locker
after that you can worry about flex if you still think you need to, but the only advantage your Jeep friends will have is that they will fit down trails that your fullsize will not.
Old 10-23-2004, 09:59 AM   #11
LONGHAIR
I wouldn't put a true "locker" in the front of anything, for at least 2 reasons.
1) A truely locking diff (detroit) will be very qwerky and jerky on the front axle.
2) Even more importantly, you will break axles with one. If you have anything moderately large tire-wise, the short side axle can't take it very long. Big horsepower and a stick-shift add to the problem.
You are far better off with a True-track or a Torsen type differential if you want "posi" on the front.
LONGHAIR is offline   Reply With Quote
Old 10-23-2004, 05:27 PM   #12
Destructo
Running 33's and a locked front axle should be ok, but, if your joints are old you may break one.
Anything but a real locker is useless off-road, if you want traction get a real locker, or better yet a selectable ARB for the front and a regular locker for the rear.
A Torsen differential may work fine, but I prefer 100% to both wheels, whatever you do though don't weld the front!
Of course i'm talking about "real" off-roading here where your not worried about how it handles on the street too much.
I welded the rear axle on my zuke, and I would not hesitate to lock the front if I had power steering and wasn't selling it...
Old 10-24-2004, 02:56 AM   #13
1FaastC10
1FaastC10's Avatar
you change your mind more often than most people change their underwear.
Old 10-24-2004, 08:38 PM   #14
Devil'S Ride
Those are two pics of my full size, 3/4 ton, 4" lift, worn out, "W" shaped front springs, POS block lift rear, attached sway bar tucking under a set of 33" M/T's running 33lbs of air all the way around....... It flexs pritty good...IMO
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 10-26-2004, 12:44 PM   #15
Prerunner1982
Prerunner1982's Avatar
i dont know about flex, but i have complete faith in this 65 k10 (my fathers)... it has a 283 out of a 58 vette, SM420 trans, 3.73 gears with rear posi. it regularly hauls 2.5tons of water like its nothing..and thats even starting off in 2nd gear..
Prerunner1982 is offline   Reply With Quote
Old 11-04-2004, 10:00 PM   #16
earl87gta
earl87gta's Avatar
I run lockers in front and rear just doble stick your transfer case so you can disingage the front in a possition ware you need a little more turning and when on the street thats what lock out hubs are for alot of guys will even only lock one hub on trails with a lot of turns. Or you can use hydrolic steering and not worry a bought it. mY blazer has 36in tires on it with recentered hummer wheels and Im running D60 in the front 14blt in the rear so I havent busted any thing yet but im sure I will some day.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-04-2004, 11:09 PM   #17
Destructo
running with one hub locked is asking for trouble, talk about breaking axles hehe.
With a locker you shouldn't need hydraulic steering or to unlock one hub, i'v only seen that needed when you weld the front, a locker should let the tires turn unless your putting a load on it.
Old 11-04-2004, 11:38 PM   #18
1FaastC10
1FaastC10's Avatar
simple solution, unlock the hubs, shift transfer case to 2wd. no input to locker, no lock.
Old 11-04-2004, 11:47 PM   #19
LONGHAIR
and no point!
Yeah, spend the money for a locker and then disable it. You might as well have a 2 wheel drive truck, Oh and put the locker on the front seat
Old 11-04-2004, 11:51 PM   #20
earl87gta
earl87gta's Avatar
My truck is a bear to turn with out the hydrolic ram at an alomost dead stop on the trail with the locker it it does want to turn sharp and tends to walk side ways so I just disingage the front end and leave the rear in low. after I turn back to 4 low. the only time it gives me a scarry ride on the street is in snow some times it will leave you white knuckled if you have it in 4x4. I dont sugest a locker in the snow untill you are use to having one in the front.
Earl
Old 11-04-2004, 11:54 PM   #21
Destructo
I have a gov-loc in the rear on my truck, which is now broken, but it likes to go all fishy in the road when it snows, I can't imagine a locker would be much worse, but you have to learn how to drive with it, but I know guys who drive in the snow with a front and rear locker without any problems.
Old 11-05-2004, 12:01 AM   #22
earl87gta
earl87gta's Avatar
I havent broken a locker yet in this set up but in the old 12b d44 I was olways breaking somthing.
Earl
Old 11-05-2004, 03:54 PM   #23
chipotledude05
Strategery
Thanks for all the replies fellas. This thread has gotten pretty interesting. I seriously doubt that I'm going to install any lockers in my truck at the moment. I don't plan on getting that serious, and I've seen my dad's truck, which is of the same era, crawl out of door deep mud and do some other pretty cool stuff with just stock equipment, and I think I'll be attending college in Boulder, CO...plenty of snow there.
Ok, I've had a question for a while: what does double sticking do for your tcase? I can't do it to my t221 because I don't think it was made for that, and I don't think I'd want to modify it that heavily, however, I'd still like to know how the double sticks work.
Thanks,
Matt
Old 11-05-2004, 06:35 PM   #24
1FaastC10
1FaastC10's Avatar
and no point!
you drive around with your truck in 4wd all the time? seems pretty retarded to me since part time cases have been an option since at least '67. use the locker when you need it, disengage it when not needed. easier on tires, front axle parts, steering parts, transfer cases, and not to mention gas.
Old 11-06-2004, 12:34 AM   #25
LONGHAIR
Not at all This has never been about everyday street driving, otherwise you wouldn't even entertain the idea of a "locker" in the front.
We are talking about 'wheeling here.......
I totally agree about the "part-time" thing. The whole NP203 was nothing but a dumbass attack.
