Old 10-22-2004, 09:56 PM   #1
Question More Power Steering Conversion Questions..
Putting powersteering on my 70. I believe the box I have is from 77 or 78 C10. My question is, can I use the pittman (I think that is waht the arm is on the box) from the newer truck or do I need to find a power steering pitman from a 68-72 to use on the newer box.
Also, as I pull these parts, will I need anything else off the newer truck (idler arm??) to make the box work?
Old 10-22-2004, 10:06 PM   #2
bigskiohio
I not positive but should all fit .
bigskiohio is offline   Reply With Quote
Old 10-22-2004, 10:08 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
all i did was pulled the box and pump off of the truck, took it home and put it on. didnt replace anything. i shoulda done the rag joint but o well. it was off of an 86
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
