Old 10-22-2004, 09:56 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
suspension question
Which suspension would be better for carrying a load of 500lbs or towing a trailer that weighs 1500-2000lbs. The 2wd coil suspension or the K5 leaf spring suspension? I don't really need a 4x4 but I need the truck for work.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 10-22-2004, 10:22 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Not That This Helps Answer Your Question, But My 70 "click On The
$500.00 Link" Has A 250 Inline 6, 350 Turbo Tranny, 4:10 Gears, Custom
Class 5 Hitch (stronger Than A 4) And I Pulled 6000 Lbs. To Memphis
And Back. (2.5 Hrs. Round Trip) Oh Yea, She Has Coils And She's Also
Slammed Ridin On The Snubbers All The Way Around, Pulled Fine.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-22-2004, 10:44 PM   #3
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Are you the one that has your picture next to the word "CRAZY" in the dictionary?
What were you towing round trip that weighed 6000lbs?
Old 10-22-2004, 11:00 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
YUP, THAT'S ME, HERE IS THE RUN DOWN OF THE LOAD
1967 SWB FLEETSIDE WITH A 400 SB AND POWERGLIDE ( COMPLETE TRUCK )
3 350 ENGINES / 1 400 ENGINE / 1 350 TURBO TRANNY / 7 BELL HOUSING'S
VALVE COVERS / CARB.'S / 3 SETS OF HEADERS / AND SOME SMALL STUFF
( ALL OF WHICH WAS LOADED INTO THE BACK OF THE 67 PICK-UP ABOVE )
DUAL AXLE HD BOXED FRAME 8 X 20 DOVETAIL PRESSURE WASHING TRAILER
WE UNLOADED TO PUT MY STUFF ON, IT WAS SO HEAVY IT USED 2 5/8 BALL
( SUPER CHEVY IN MEMPHIS 2001, BURNED 5 QUARTS OF OIL ROUND TRIP )
Old 10-23-2004, 01:05 AM   #5
bad_turbo
turbo enthusiast
bad_turbo's Avatar
and that 6 cylinder pulled all that? Must not of had any hills.
Old 10-23-2004, 01:17 AM   #6
tommo
Junior Member
i would say coil sprung suspension, less axle wrap than leaves, but 500 lbs isnt too much either way. if you use a 'soft ride' style lift leaf spring the wrap gets worse than you would think.
good luck.
tommo
tommo is offline   Reply With Quote
Old 10-23-2004, 08:14 AM   #7
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Leaf springs....
Leaf springs are 100% better than a coil spring suspension to tow, I used to have a C-10 with coils and whenever I towed with it always seemed to be moving around like crazy and it wasn't that stable and it even had auxiliary leaf helpers, now my 3/4 ton with leafs doesn't do that, that's why I prefer the leaf over the coils for towing.
That axle wrap that tommo describes might happen if you had a race truck with a lot of power (it would be an empty truck) therefore making your rear axle hop around like crazy, that's when you would have axle wrap, but when towing you have a load pushing down on the back of your truck so axle wrap wouldn't be as big of a problem here, just my .02
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
