Old 10-23-2004, 03:41 AM   #1
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Neutral saftey switch
How do I wire around it so it will start in any gear? It's a 78 model Chevy.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-23-2004, 03:42 PM   #2
PHOENIX
Auto or Manual trans?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 10-23-2004, 08:54 PM   #3
1972C10
1972C10's Avatar
Connect the purple wires together .. If its an auto they will be on top of the colum Standards are base off clutch pedal being down all the way.
1972C10 is offline   Reply With Quote
Old 10-24-2004, 02:23 PM   #4
Brainchild
Brainchild's Avatar
It's an Auto,and the wires are purple and yellow with purple stipe,does this sound right?
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-24-2004, 08:31 PM   #5
Brainchild
Brainchild's Avatar
I just looked at the truck again,and there is another plug on the right side that has two smaller wires coming from it they are green/blue,couldn't really see up there in the dark.Anyway,what are they for?
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 11-26-2004, 07:03 PM   #6
Brainchild
Brainchild's Avatar
Ok this truck has two sets of wires running to a switch on the bottom of the column I assume this is the neutral saftey,right?
Two big wires,one purple,and one yellow,and two small wires,one green one brown.I placed a wire jumping the 2 big wires together,and one connecting the two smaller wires,and I still have to he-man the shifter to get it to turn over.
I also adjusted the linkage to the tranny,and same thing,will not start unless I pull up on the shifter,and I mean YANK! it towards park.
What am I missing here??
I will start with all the wiring undone from the switch,and no jumpers so apparently the switch isn't the one I need.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 11-26-2004, 11:48 PM   #7
jimfulco
Try moving the switch slightly clockwise (looking from the rear) on the column.
jimfulco is offline   Reply With Quote
