Old 10-23-2004, 04:19 PM   #1
Harold Shepard
Need Help/ advice
The truck I am currently working on is in line to get new suspension, my question is how difficult is it to put an air bag setup on and what setup do you recommend? The truck is a 69, but I am putting 71/72 discs up front. Second question where to locate the compressor- I am relocating the gas tank to the rear and can I place the compressor in the rear as well?? Wht are some of you doing. Third question I have seen some of the filler relocations that you have done to the marker light and plan on the same with this truck- question is what year are you taking the filler door/hinge from? Any help is appreciated. Harold
Harold Shepard is offline   Reply With Quote
Old 10-23-2004, 04:45 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
for front bags you can make a plate that bolts to the crossmember where the spring pocket is and a 5 inch pipe with a plate welded to one end for the bottom. as far as the gas tank i think that they were using s-10 gas tank door hindges. i will look for pictures
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 10-23-2004, 04:53 PM   #3
68w/sbc406
68w/sbc406's Avatar
http://67-72chevytrucks.com/vboard/s....php3?t=123188
some pics of bag brackets and info
Old 10-23-2004, 06:15 PM   #4
Harold Shepard
Thank you very much !!! Harold
