Apache 40 info please
Hi, I'm new to this forum and also to these trucks. I found a Apache 40 (1961 as per the grill ) with a inline 6 cyl that I can get for very cheap. The problem is it's in bad shape.
Frame seems ok, so does the cab and hood, all window are ok, interior is acceptable, but it doesn't have a bed, and the front fenders and the 2 doors would need to be changed. So, here are my newbe questions: #1: What's the meaning of the 40 ?(I saw a lot of Apache10 here but never heard of a 40) #2: Hoe to know if it was a long or short bed (and fleet or step side)? #3: What year can I pick parts from to keep the 61 look? (the doors, front fenders, bed?) #4: If you have any other usefull info or tips don't be shy to share with me! Thanks! |
sounds like that might be a medium duty truck that would explain the no bed
it might have been a stake bed or a flatbed witch has long since roted away or been removed. Thies bigger trucks are harder to work on and find parts for though most of the cab and front panles are shared with its smaller conterparts heres are a few things you should look for first see if you can find its gvw tag should be on the drivers side below knee high (sitting down) also check and see what kind of trany its got big trucks tend to have the 4 speed sm420 with granny gear oh and this site should deff help you id your truck http://www.6066gmctrucks.org/GMCID1.htm |
Professional Beer Tester
What size tires are on that truck? A 40 series is a big truck, which should have came with 20" or 22.5" wheels. 10 is 1/2 ton, 20 is 3/4 ton, 30 is a 1 ton, and 40 thru 80 series were big trucks, 1 1/2 ton and up. If it is a 40 series, it would not have come with a pickup bed, it would have been outfitted with a flatbed or whatever was needed. Is it maybe a 40 series cab that someone put on a pickup frame? The basic cab, doors and hood should be the same between the pickup and the big truck. The front fenders and grill shell are different for the big truck. 1960-63 all shared the same cab styling. Hope that helps.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
Here's some pics of the truck in question, he seems to be in very bad shape but when seen in person it's not that bad!
You're probably right for the flatbed. Actually this is what it's got but we thought someone put it there to replace a rusty pickup bed and I don't think they even replce the cab so it must be an whole 40 truck (maybe I could have foud it out by looking the susension but I don't know what are the difference between the year/models etc...)... I'll have to go see it again and find some VIN and GVW... Thanks and keep posting if you have anything to add! Last edited by blackZ34; 10-26-2004 at 02:34 AM. |
Sorry Budd, don't know what's wrong, but I can't open the pics. I click on the red X and absolutley nothing happens. Must be something I'm missing, that happens often. Let me know if you can tell me what's wrong, I'd like to see the pics of that truck. Thanks!
60-66 Nut
I tried to upload them from my PC and add them as an attachement, is it how we're supposed to do it?
Anyway, try those links instead... (I hope those works!) Apache40_01 Apache40_02 Apache40_03 Apache40_04 Last edited by blackZ34; 10-26-2004 at 02:18 PM. |
I can see! Yep, that's a 40 series truck, alright. I actually haven't seen many 40's, mostly the 50, 60, 70 and 80 series. I was thinking it would look more on the lines of the bigger series, but it actually looks more like a heavy-duty 1 ton. As I said before, most of the big trucks I've seen use a taller grill shell, bigger front bumper and the front fender wheel openings are extended outward. They also usually have running boards. This truck looks more like a pickup, same bumper and grill, the wheel openings look like they may be a little longer than a 1/2 ton. The wheels and tires also look more like what would have been used on the 1 ton trucks. Probably a pretty rare truck. Do you have any idea where it was built or purchased? I'd like to know more about it. I love these old trucks, especially the big trucks. I've worked on big trucks since I was a kid. About 30 years ago, I worked as a mechanic's helper in a small country garage. We worked on just about anything, cars, trucks, tractors, you name it, we probably worked on it. But my favorite has always been old stuff like farm trucks, dump trucks, etc. Good luck and post more pics if you can.
60-66 Nut
I'll try to find more info on the truck (maybe friday). The owner is actually one of my friends (well, not really him, his father was but he just past away a couple months ago..) and I didn't even know he had this! He said it had been sitting there for 14 years, I don't know if they were the originals owners...
I'll try to get some measurement of the wheel opening and wheelbase, etc... I know it has a inline 6 in it that MIGHT be still working (they stopped it in oil...) They were tobacco producer so that's why they had bought the truck. Dumb question#1: would it be possible to put a regular bed on it? Dumb question#2: what would be involved if I wanted to bag it? |
Probably the hardest part involved with putting a pickup bed would be if the wheelbase is too long, then the frame would have to be cut. Then if the frame is strait behind the cab like a big truck, you may have to fabricate mounts for the bed. Also if the rearend has dual wheels, which it probably does, the bed might not fit between the inside wheels, and the outer wheels would stick out. If I see correctly in the picture, it has a bolt pattern that might be hard or nearly even impossible to find single wheels for. By "bagging" it, I assume you mean putting air bag suspension(not real up on some of the new terminology). Most 60-62 GM trucks had torsion bar suspension in the front, even some of the heavier trucks. I don't know a whole lot about the air bags, so I can't tell you if it works with torsion bar suspension or not. I know someone here can tell you for sure. You might be easier finding a 1/2 ton donor truck for the running gear, or maybe even the whole frame. I'm not sure what you want the truck for, but keep in mind the rear end probably has low gears from hell, the engine will be screaming at 50-60 mph. It'll pull the house if you can find a place to hook it, but not real nice for a cruiser.
60-66 Nut
Yes by bagged I meant putting air bags! I'd have to ask some people around here that know air suspension very well (they have a shop installing those).And if I remember right, it doesn't have dual wheels, I'd have to look at the frame to see how it is but I don't mind to fabricate some mounts to put a pickup bed on it, I just don't like the look of a flatbed!!!.
I found something in another thread, looks like it should have the torsion bar (if you look closely at the bottom of the page you see it's for 10-40 series) torsion bar |
Slots go on anything!
I wonder if it would be better to put the cab on a later model (63-66) frame and do it up that way.
1974 Jimmy- 5.3/4L80e/NP241 |
As far as size it looks preaty close to my c30 so you might be able to get a 1 ton bed on it with a little fabrication.
#13 |
a 62 bed comes compleatly apart so modifying it would be very easy
i hope this helps you out ![]() ![]() |
#14 |
I have some news!!
I finally found the VIN tag. I knew where it was supposed to be, the only thing is that the driver side door was jammed closed ![]() The serial# is 1C4103606*****C According to this page:VIN decoder , everything matches (the only exception being is that the series/model are under 1962 but maybe the guy who did this page didn't know they existed in 1961 too) I measured the wheelbase and 133" seems correct. It does have the torsion bar in front and leaf on the rear. I tried to find a VIN tag on the left frame but nothing I could see, maybe it was too dirty or I wasn't looking the good spot... I'll post some other pics soon! |
#16 |
looks like thats gona be qwite a project especaly the body work probly gona have to replace or weld alot of panles. but who knows that old 235 with a little time and care might fier right up
#17 |
Now I see why it doesn't have dual rear wheels anymore, someone put an 8 lug rear end under it, which could be from a 3/4 ton or a single wheel 1 ton. The front wheels looked like 10 hole in the first pics you posted, but I couldn't be sure. These pics are much better. The front hubs have only 5 lugs, but are made to use the same wheels as the rear end would have had. The original rear end probably had all 10 lugs and used 4 wheels like the front ones. The inside wheels would have been turned inward like the fronts, and the outside wheels were turned around the other way with the offset facing outward. Keep us posted.
60-66 Nut
