![]() Join Date: Apr 2002
how to remove rear u bolts?
I know this seems a simple question. But does anybody have a trick on removing the rear u bolts on a "72" Have tried a strong arm and a 3' cheater bar, but only got a sore back!
72 chevy C-10 swb fleetside,402 BB.700r4,buckets,console.etc. 72 Blazer CST 350,AT, new project 1971 Chevy Nova ,355 SB blow through turbo in works. |
Fire.........Heat. You can either heat the nuts or cut the u-bolts and put in new ones.
If you don't have a oxy/acc torch to cut with a common porpane torch will do the heating part. |
67-72 parts collector,…
![]() Join Date: Nov 2002
cut em! I use a die grinder with a cut off wheel.
67 is sold
Yep - when disassembling my wrecked 67 frame, I cut the bolts
Straight jacket required
a good method is to heat em up and theyll come right off. I did mine that way and it was easy.
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
![]() Join Date: Jun 2002
I tried heat(oxy/ace) and a 10' cheater and still ended up cutting the bolts with a die grinder.
Be careful, there's alot of stress on those u-bolts and when they give it can scare the crap out of you... Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
Keepin an eye out
I also ended up cutting mine off.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Guess I've had good luck...
Just sprayed mine with penetrating oil several times...used a cheater bar, came right off.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
HEY HEY I got them off,after cutting with a die grinder,and they do pop and scare the crap out of you the first time! Live and learn!!
A good 1/2" 500ft/lb torque air impact gun usually does the trick for me.
Yeah, I've got knots on my head from that popping noise...
A classic GM kinda guy
An old trick I used to use on "stubborn" bolts:
Heat the offending bolt and nut with a torch, then cool the bolt down with penetrating oil. Works great, especially on those stubborn exhaust manifold bolts.
Old school rap music: a dual exhausted GM 6 with no mufflers. "If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s. "I did. They are called Classic GM pickups !!!" ![]() ![]() |
