Old 10-23-2004, 09:23 PM   #1
cgrossl
Repro Door Handles Causing Doors not to Unlock?
I just got through having my truck painted. I had my body man install new, reproduction door handles on the finished truck. If I puch the lock button down on the doors, then shut them, they will sometimes be impossible to unlock. You just can't pull the lock button up. To fix this condition, I have to wiggle the rod around that goes from the door handle to the door latch. Then the door will unlock fine. I compared the factory and the repro door handle and they are a little different. It looks like the linkage rod needs to be a little longer to work with the repro door handle. Is there any tricks to getting the repro door handles to work correctly?
cgrossl is offline   Reply With Quote
Old 10-23-2004, 10:35 PM   #2
cliffsta
Stepsides RULE
cliffsta's Avatar
Inside door handles?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-24-2004, 12:56 AM   #3
soleeagle
soleeagle's Avatar
If you are talking about outside door handles I have the same problem myself. As of now I just dont lock them untill I get a chance to figure out how to solve the problem. So I would also like some info on ow to fix this.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 10-24-2004, 05:54 AM   #4
1972C10
1972C10's Avatar
My 85 Did that with the factory Handles I always thought it needed oiling. What i had to do if the rod got hung in the down position Is push the door handle button That normally free'd it up .
1972C10 is offline   Reply With Quote
Old 10-24-2004, 10:35 AM   #5
80BIG10
3 lefts make a right
80BIG10's Avatar
I have that problem from time to time on my truck. I find that if the key wont want to turn I just have to push in the handle button and then the key turns and unlocks fine.
80BIG10 is offline   Reply With Quote
Old 10-24-2004, 07:41 PM   #6
cgrossl
I got it fixed today. I took the rods out and ground some more clearance on the cap end of the rod to allow the rod to go down farther. I also lubed everything with grease. They work fine now.
