-Chris
![]() Join Date: Sep 2002
Widest wheels to use on 66?
I need to know what is the deepest wheel i can use on my stock stance frame? Right now i have 15" x 10" deep aluminum bajas i want to try to use but I dont know if they will fitr under the bed of the truck. If these wheels will work, I would also like to know what the widest tires i can run. Will 50 series fit without rubbing? Thansk for any help.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
50 series has nothing to do with the width, p275 50 is the same width as a p275 60, the 60 will have a taller side wall height. You should be fine if your at stock ride height, and if dont plan on haulin anything. To be safe I wouldnt go any wider than a 275. I had 275 on an eight inch wheel on mine before I lowered it three inches and they barely rubbed when I took a corner alittle to fast.
64 Chevy pickup tilt,pb, ps discs up front 350/TH350, 72 rearend auto meter gauges 93 GMC extended cab trailmaster conversion |
-Chris
so....Ihave10inch wheels. So they probably wouldnt do to good huh?
I would'nt think so, unless they have four or five inches of backspacing.
