Old 10-24-2004, 11:37 AM   #1
72 3/4 ton
Wood bed replacement
This wood bed hit every ugly branch when it fell from the tree. Any suggestions here? I will be using it as a work truck to haul tools and wood. Has any body tried to use the plastic/nylon synthetic wood? How about the hold down strips (is that what they are called)? Can they be replaced or should I try and save them? I was planning on replacing the wood bed then getting a mat to cover the bed. What's it take to make it a metal bed?
Opinions?
72 Chevy 3/4
99 Suburban 4X4
91 S10 Tahoe
88 IROC
71rsZ28
28 Model A Tudor
72 3/4 ton is offline   Reply With Quote
Old 10-24-2004, 11:51 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
The metal stips are available and not too expensive. Since the wood is 3/4" thick, it would be difficult to change it to a metal bed. I know there was some discussion on using other materials like synthetic wood and aluminum. I have a step side with less wood then yours, but the PO put in one full piece of 1/2" plate steel to cover the old rotted wood! ...
Rich
1972 K5 Blazer CST Click HERE
Old 10-24-2004, 12:12 PM   #3
72 3/4 ton
Thanks for the input.
1/2 plate??? Wow that's got to weigh a lot!
This wood is really rotten and it's hard to tell if the wood is groved, notched or is it just straight material with straight cuts and no extyra work?
72 Chevy 3/4
99 Suburban 4X4
91 S10 Tahoe
88 IROC
71rsZ28
28 Model A Tudor
Old 10-24-2004, 12:16 PM   #4
Harold Shepard
It has a groove for the strips to fit into and lock it into place. The synthetic wood seems like the way to go if you were going to use the truck- if it comes in 3/4 thicknesses.
Harold Shepard is offline   Reply With Quote
Old 10-24-2004, 12:49 PM   #5
mcmlxix
mcmlxix's Avatar
oops .. .. its 1/4" ... I dont know what I was thinking..
Rich
Old 10-24-2004, 02:54 PM   #6
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
One option that we have done on the farm is weld in steel checker plate.
Works good on a work truck. Dad did a 66 like this.
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 10-24-2004, 04:06 PM   #7
dwaite72lnghrn
You could use pressure treated 2x6 and 2x8 you will need to cutoff all the old bolts from the strips. Use new 2-2 1/2" carriage bolts in the old strips. Plastic/synthetic wood needs closer spacing than the bed has, you will have some soft spots if you use that. I replaced mine in a weekend with PT, The bed will sit 3/4" higher than normal but for a work truck it don't matter. You will have to route 3/4" off the bottom side where it mates to the front of bed. You could also run a rabbit down the top sides for the metal strips if you want but it is not needed. you will need to reuse the large bed bolts or get new 3/8" bolts to anchor it to the frame.
This bed has been in for 20 years and just had a paint job on it.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 10-25-2004, 09:44 PM   #8
72 3/4 ton
Thanks for the info dwaite72lnghrn. 3/4" higher sounds Ok. It will give me a goo reas on to get some bigger rims and tires to fit the wheel well.
72 Chevy 3/4
99 Suburban 4X4
91 S10 Tahoe
88 IROC
71rsZ28
28 Model A Tudor
Old 10-25-2004, 11:20 PM   #9
WB72
Before and After
WB72's Avatar
How about using a couple of sheets of 3/4" plywood and having one seam down the center? I was going to do that before I restored mine. I think it would work great for a truck that will be used as a truck.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 10-25-2004, 11:38 PM   #10
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
if you want t metal bed i will trade ya
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 10-26-2004, 01:21 AM   #11
camelot
GMC Paul's has a link to wood bed info if you are replacing it yourself: http://www.gmcpauls.com/47-72%20BedWood%20Info.htm
Camelot
www.toyotagirl.com
1985 Chevy 4Runner
1972 GMC 4WD
camelot is offline   Reply With Quote
